Hi, I am a student working on a custom PCB with an ESP32-WROOM-32E module in a Project course.
I use FT232R as USB-UART bridge. I am having problems with EN pin dropping below the required voltage for chip to be turned on. I have changed capacitor value between EN and GND with no success.
Schematics: https://drive.google.com/file/d/1LMw0G- ... Y5YcX/view
NOTE: I only have Power Supply, Main MCU, USB to UART Bridge and Strapping Buttons connected. I don't have any Auto Programming circuitry.
Measurements with oscilloscope (Yellow: EN , Blue: 3V3):
https://cdn.discordapp.com/attachments/ ... nknown.png
I have changed PCB layouts and manufactured the PCB few times now and changed WROOM modules (I tried WROOM-32D and WROOM-32E) and the result is the same. Could anyone please help me understand why this is happening?
Unstable EN voltage
Re: Unstable EN voltage
Interesting. Nothing in your schematic looks wrong. Possibly it's something weird, like a cracked ceramic capacitor on C5?
ZeroxCorbin
Hello, have you gotten any resolution to this? I am experiencing the same thing.
I have several iterations of the same board with the same problem. It runs well for like 20 mins before EN fluctuates.Interesting. Nothing in your schematic looks wrong. Possibly it's something weird, like a cracked ceramic capacitor on C5?
I ended up throwing out the design and using the ESP32-DevKitC-V4 with an external 3V3 regulator (I have desoldered the one on the DevKit). It works well. The problem with the new design is that whenever I have used the Adafruit's 20-pin 0.1" Female Headers as an adapter, it stopped working. I ended up removing the DevKit's unused pins (as an extra precaution) and soldering the remaining ones on the board. It works now, but I don't like this 'hack'.Hello, have you gotten any resolution to this? I am experiencing the same thing.
Does not work with these headers: https://cdn.discordapp.com/attachments/ ... image0.jpg
This solution works: https://cdn.discordapp.com/attachments/ ... image0.jpg
Users browsing this forum: Baidu [Spider] and 5 guests
