ADF BLE Sink no longer working
Electronics-noob
Postby Electronics-noob » Sat May 08, 2021 8:18 am
Hello!
I’ve recently started a speaker project and deicided to use a ESP32 for it since I had a few laying around at home.
I installed the ADF (cloned from GitHub) a while back and got things working with the example code "BLE Sink" then changed some things and it still worked.
I updated both ADF and IDF recently and now I can’t get anything to work. I had a hard time to compile so when back to IDF release v4.2 and tried ADF 2.2 (did not work) and ADF master branch. The master branch allows me to compile the code and flash but i get warnings and the code runs unstable and crashes after a while.
I’m not sure what’s going on, I’m not too familiar with the IDF/ADF frameworks, does anybody have an idea?
Any help would be appreciated!
I’m currently using:
IDF v4.2
Lates ADF clone.
ESP32-WROVER
Below is the code. Its just a stripped version of the BLE sink code. The original example seems to act the same.
/* Play music from Bluetooth device
#include <string.h>
#include "freertos/task.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "audio_element.h"
#include "audio_pipeline.h"
#include "audio_event_iface.h"
#include "audio_common.h"
#include "i2s_stream.h"
#include "esp_peripherals.h"
#include "periph_touch.h"
#include "periph_adc_button.h"
#include "periph_button.h"
#include "filter_resample.h"
#include "audio_mem.h"
#include "bluetooth_service.h"
static const char *TAG = "BLE Sink";
void app_main(void){
    esp_log_level_set("*", ESP_LOG_INFO);
    esp_log_level_set(TAG, ESP_LOG_DEBUG);
    audio_pipeline_handle_t pipeline;
    audio_element_handle_t bt_stream_reader, i2s_stream_writer;
    nvs_flash_init();
    ESP_LOGI(TAG, "Create Bluetooth service");
    bluetooth_service_cfg_t bt_cfg = {
        .device_name = "Ruski Hardbass",
        .mode = BLUETOOTH_A2DP_SINK,
    bluetooth_service_start(&bt_cfg);
    ESP_LOGI(TAG, "Create audio pipeline for playback");
    audio_pipeline_cfg_t pipeline_cfg = DEFAULT_AUDIO_PIPELINE_CONFIG();
    pipeline = audio_pipeline_init(&pipeline_cfg);
    ESP_LOGI(TAG, "Create i2s stream to write data to codec chip");
    i2s_stream_cfg_t i2s_cfg = I2S_STREAM_CFG_DEFAULT();
    i2s_cfg.type = AUDIO_STREAM_WRITER;
    i2s_stream_writer = i2s_stream_init(&i2s_cfg);
    ESP_LOGI(TAG, "Get Bluetooth stream");
    bt_stream_reader = bluetooth_service_create_stream();
    ESP_LOGI(TAG, "Register all elements to audio pipeline");
    audio_pipeline_register(pipeline, bt_stream_reader, "bt");
    audio_pipeline_register(pipeline, i2s_stream_writer, "i2s");
    ESP_LOGI(TAG, "Link it together [Bluetooth]-->bt_stream_reader-->i2s_stream_writer-->[codec_chip]");
    rsp_filter_cfg_t rsp_cfg = DEFAULT_RESAMPLE_FILTER_CONFIG();
    rsp_cfg.src_rate = 44100;
    rsp_cfg.src_ch = 2;
    rsp_cfg.dest_rate = 48000;
    rsp_cfg.dest_ch = 2;
    audio_element_handle_t filter = rsp_filter_init(&rsp_cfg);
    audio_pipeline_register(pipeline, filter, "filter");
    i2s_stream_set_clk(i2s_stream_writer, 48000, 16, 2);
    const char *link_tag[3] = {"bt", "filter", "i2s"};
    audio_pipeline_link(pipeline, &link_tag[0], 3);
    ESP_LOGI(TAG, "Initialize peripherals");
    esp_periph_config_t periph_cfg = DEFAULT_ESP_PERIPH_SET_CONFIG();
    esp_periph_set_handle_t set = esp_periph_set_init(&periph_cfg);
    //ESP_LOGI(TAG, "Initialize Touch peripheral");
    //audio_board_key_init(set);
    ESP_LOGI(TAG, "Create Bluetooth peripheral");
    esp_periph_handle_t bt_periph = bluetooth_service_create_periph();
    ESP_LOGI(TAG, "Start all peripherals");
    esp_periph_start(set, bt_periph);
    ESP_LOGI(TAG, "Set up  event listener");
    audio_event_iface_cfg_t evt_cfg = AUDIO_EVENT_IFACE_DEFAULT_CFG();
    audio_event_iface_handle_t evt = audio_event_iface_init(&evt_cfg);
    ESP_LOGI(TAG, "Listening event from all elements of pipeline");
    audio_pipeline_set_listener(pipeline, evt);
    ESP_LOGI(TAG, "Listening event from peripherals");
    audio_event_iface_set_listener(esp_periph_set_get_event_iface(set), evt);
    ESP_LOGI(TAG, "Start audio_pipeline");
    audio_pipeline_run(pipeline);
    while(1){
        audio_event_iface_msg_t msg;
        audio_event_iface_listen(evt, &msg, portMAX_DELAY);
        if (msg.source_type == AUDIO_ELEMENT_TYPE_ELEMENT && msg.source == (void *) bt_stream_reader && msg.cmd == AEL_MSG_CMD_REPORT_MUSIC_INFO) {
            audio_element_info_t music_info = {0};
            audio_element_getinfo(bt_stream_reader, &music_info);
            audio_element_setinfo(i2s_stream_writer, &music_info);
            i2s_stream_set_clk(i2s_stream_writer, music_info.sample_rates, music_info.bits, music_info.channels);
            continue;
               // Stop when the Bluetooth is disconnected or suspended
        if (msg.source_type == PERIPH_ID_BLUETOOTH
            && msg.source == (void *)bt_periph) {
            if (msg.cmd == PERIPH_BLUETOOTH_DISCONNECTED) {
                ESP_LOGW(TAG, "[ * ] Bluetooth disconnected");
        // Stop when the last pipeline element (i2s_stream_writer in this case) receives stop event
        if (msg.source_type == AUDIO_ELEMENT_TYPE_ELEMENT && msg.source == (void *) i2s_stream_writer
            && msg.cmd == AEL_MSG_CMD_REPORT_STATUS
            && (((int)msg.data == AEL_STATUS_STATE_STOPPED) || ((int)msg.data == AEL_STATUS_STATE_FINISHED))) {
            ESP_LOGW(TAG, "[ * ] Stop event received");
    ESP_LOGI(TAG, "Stop audio_pipeline");
    audio_pipeline_stop(pipeline);
    audio_pipeline_wait_for_stop(pipeline);
    audio_pipeline_terminate(pipeline);
    audio_pipeline_unregister(pipeline, bt_stream_reader);
    audio_pipeline_unregister(pipeline, i2s_stream_writer);
    // Terminate the pipeline before removing the listener
    audio_pipeline_remove_listener(pipeline);
    // Stop all peripherals before removing the listener
    esp_periph_set_stop_all(set);
    audio_event_iface_remove_listener(esp_periph_set_get_event_iface(set), evt);
    // Make sure audio_pipeline_remove_listener & audio_event_iface_remove_listener are called before destroying event_iface
    audio_event_iface_destroy(evt);
    // Release all resources
    audio_pipeline_unregister(pipeline, filter);
    audio_element_deinit(filter);
Users browsing this forum: Amazon [Bot] and 1 guest
