Noob question
Posted: Tue May 18, 2021 8:56 am
by jackbauer
I'm learning how to use the ESP32, so I loaded an example in the ESP32, but now I can't load another example because the current example won't be deleted. Should I format it first?
What should I do and how?
Re: Noob question
Posted: Tue May 18, 2021 9:12 am
by Sprite
What SDK (arduino, esp-idf, ...) are you using and how are you 'loading' the example?
Re: Noob question
Posted: Tue May 18, 2021 9:17 pm
by jackbauer
Hi, most info is in this topic
viewtopic.php?f=2&t=20959
Using Arduino IDE.
Re: Noob question
Posted: Wed May 19, 2021 1:48 am
by Sprite
Then, can you define 'but now I can't load another example because the current example won't be deleted. '? What do you do, what error message do you get, what would you expect to happen instead? Please be exact, at the moment your error description is about as clear as 'I tried a thing with an ESP32 and it didn't work, please help me'.
