Optimizing ESP32 WROOM-E Devkit Power Supply
alexander96
Postby alexander96 » Fri May 21, 2021 4:26 pm
Hello, I am currently developing a PCB with a ESP32 WROOM-E, I used the Devkit Schematics I found here:
https://dl.espressif.com/dl/schematics/ ... v4-sch.pdf
I am currently using this voltage regulator:
https://www.mouser.de/ProductDetail/Tex ... Dk3hw4bA==
Unfortunately the power supply of the micro usb port and 5V phone charger ist not reliable and so the ESP32 crashes if there is a power consumption peak.
My PCB should exactly work for this use case so I need to fix my PCB Design so it works even if there is a power consumption spike.
Is there a simple way in fixing the power supply by adding some components to the design or did anybody of you had similiar problems and solutions for this?
Sincerly
Alexander
alexander96
Re: Optimizing ESP32 WROOM-E Devkit Power Supply
Postby alexander96 » Mon May 31, 2021 12:00 pm
Does nobody has an idea?
The power spike occours when I read out a RFID Card with the RC522 RFID Modul an then immediately make an http request afterwards.
The problem also occours when I use the newest version auf the ESP32 Devkit with a ESP32WROOM-E so its not just my PCB design.
I also tried to change the capaciator next to the ESP32 and next to the voltage regulator from 22uf to 100uf but it didnt change anything..
Postby Sprite » Tue Jun 01, 2021 12:42 am
One of the things I noticed is that your LDO has a dropout voltage of 1.2V which is pretty high - it means proper working isn't guaranteed when the power supply drops to 4.5V. Perhaps you can change for a LDO with a less high dropout voltage?
tommeyers
Postby tommeyers » Tue Jun 01, 2021 12:54 am
IT Professional, Maker
Santiago, Dominican Republic
becorey
Postby becorey » Tue Jun 01, 2021 1:04 pm
What is your 5v phone charger rated for? 500mA, 1A, 2A?
Are capacitors close to the esp32 power supply pins? 100nF and 1uF
