OTA hangs when using I2C
theGtknerd
Postby theGtknerd » Tue May 25, 2021 2:19 pm
I am not altogether new to C++ or the ESP32, but I am running up against a problem too big for me. When trying to perform an OTA (AsyncElegantOTA if it matters), my code is also using I2C, which causes the ESP32 to throw a lot of errors like:
[E][esp32-hal-i2c.c:318] i2cDumpI2c(): i2c=0x3ffbe454
[I][esp32-hal-i2c.c:319] i2cDumpI2c(): dev=0x60013000 date=0x16042000
[I][esp32-hal-i2c.c:321] i2cDumpI2c(): lock=0x3ffb844c
[I][esp32-hal-i2c.c:323] i2cDumpI2c(): num=0
[I][esp32-hal-i2c.c:324] i2cDumpI2c(): mode=1
[I][esp32-hal-i2c.c:325] i2cDumpI2c(): stage=3
[I][esp32-hal-i2c.c:326] i2cDumpI2c(): error=5
[I][esp32-hal-i2c.c:327] i2cDumpI2c(): event=0x3ffde80c bits=112
[I][esp32-hal-i2c.c:328] i2cDumpI2c(): intr_handle=0x3ffde840
[I][esp32-hal-i2c.c:329] i2cDumpI2c(): dq=0x3ffd0120
[I][esp32-hal-i2c.c:330] i2cDumpI2c(): queueCount=1
[I][esp32-hal-i2c.c:331] i2cDumpI2c(): queuePos=0
[I][esp32-hal-i2c.c:332] i2cDumpI2c(): errorByteCnt=-1
[I][esp32-hal-i2c.c:333] i2cDumpI2c(): errorQueue=0
[I][esp32-hal-i2c.c:334] i2cDumpI2c(): debugFlags=0x00000000
[I][esp32-hal-i2c.c:311] i2cDumpDqData(): Debug Buffer not Enabled
[I][esp32-hal-i2c.c:354] i2cDumpInts(): Debug Buffer not Enabled
[I][esp32-hal-i2c.c:1138] i2cProcQueue(): Bus busy, reinit
On some OSes like Windows 10, this will ultimately cause a watchdog reset. On Linux it does perform the OTA most of the time. Since I am using FreeRTOS, I used this code, but it doesn't change a thing:
if( xSemaphoreTake( i2cMutex, 1000 ) == pdTRUE ) {
  // do I2C here
  xSemaphoreGive( i2cMutex );
So I tried:
  wheelAngleTmp = ads.readADC_Differential_0_1();
  if( Wire.lastError() != 0 ){
    vTaskDelete( NULL );
Which works, but it seems horribly hacky. I am looking for a more elegant way to detect an OTA update being done, so that I can shut down the I2C task. Or what are my other options? As far as I can tell, the OTA uses the I2C bus. There's a bit of reports of the OTA hanging problem across the Interweb, I suspect they might be related.
username
Re: OTA hangs when using I2C
Postby username » Wed May 26, 2021 2:50 am
In your OTA routine when it detects your doing OTA, you kill all other threads that are running.
theGtknerd
Postby theGtknerd » Wed May 26, 2021 11:36 am
That's the problem, I'm using a library. So what you are telling me is that I need to use my own OTA routine. I was hoping for a holistic solution other people could also use with AsyncElegantOTA.
username
Postby username » Wed May 26, 2021 11:49 am
Gotcha. Well, FWIW I copied the OTA source into my project, and just inserted a few lines.
Vader_Mester
Contact:
Postby Vader_Mester » Wed May 26, 2021 1:10 pm
Maybe you are not required to modify the library.
First you must create a FreeRTOS task that calls AsyncElegantOTA.loop();
static void otaSuperVisor(void *pVparams)
	while(1)
	vTaskDelay(5000/portTICK_PERIOD_MS);
How often are you using I2C? Are you using it as a fixed frequency, or code decides to call it?
task_t coffeeTask()
	while(atWork){
			coffeeDrink(mug);
	vTaskDelete(NULL);
theGtknerd
Postby theGtknerd » Wed May 26, 2021 5:26 pm
It's set up using
void sensorWorker10HzPoller( void* z ) {
  constexpr TickType_t xFrequency = 100;
  TickType_t xLastWakeTime = xTaskGetTickCount();
  for( ;; ) {
    // I2C here
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
xTaskCreate( sensorWorker10HzPoller, "sensorWorker10HzPoller", 2048, NULL, 5, NULL );
theGtknerd
Postby theGtknerd » Wed May 26, 2021 5:31 pm
I may have to roll with that and be happy. It's just odd this problem hasn't surfaced before and gotten a proper fix. If I knew more about callbacks, I would be tempted to add a callback to the OTA library, and use that to shut down the I2C tasks. That would be a nice way for future people to hook into.
Vader_Mester
Contact:
Postby Vader_Mester » Thu May 27, 2021 5:41 am
You don't want to run the OTA server all the time, just when you want to deploy a new firmware.
This OTA lib already needs a server. You don't call ota.begin() in the setup() function. You register a server request to it.
It is also advised to create the OTA loop task in setup().
Then your loop task will be:
static void otaLoopTask(void *pVparams)
        vTaskSuspend(NULL); //suspend ourselves
        vTaskDelay(1); //Delay for 1tick is needed so that the idle task properly suspends this task and we won't enter the while loop
	while(1)
Then you register the request to enable OTA:
Like
  server.on("/iwannaota", HTTP_GET, [](AsyncWebServerRequest *request) {
     request->send(200, "text/plain", "Activating OTA platform");
     AsyncElegantOTA.begin(&server);
     vTaskResume(otaLoop); //Handle for the otaLoopTask must be used here
This will activate the OTA function, and resume the loop task.
You just type into your browser: http://esp32.ipaddress/iwannaota and your OTA webpage will be avalable for use afterwards.
You can of course make a simple site hosted by the ESP, on which you just place a button to do the same thing.
This way the OTA is only running when you say so, but does nothing as long as it is not needed.
task_t coffeeTask()
	while(atWork){
			coffeeDrink(mug);
	vTaskDelete(NULL);
theGtknerd
Postby theGtknerd » Thu May 27, 2021 10:46 am
Thanks, @Vader_Mester. That looks promising. It's a bit of code to digest, but I'll work on it. :D
