Is there a way to use esp32 as bluetooth host and client at the same time
spacebiker
Postby spacebiker » Wed May 26, 2021 3:27 pm
I need to connect smartphone to esp32 and send audio stream, but esp32 I also want to connect with headphones and send audio. So for smartphone esp32 is client, but for headphones it is host. Is it possible to make two connections like this?
ns1668
Re: Is there a way to use esp32 as bluetooth host and client at the same time
Postby ns1668 » Thu May 27, 2021 2:09 pm
True wireless headphones use a custom implementation to stream audio to two headphones at the same time - typically the stream is sent to one headphone, when then forwards the audio stream to the other headphone. You could try research that, I am unaware of any open source implementation.
Good luck!
Users browsing this forum: Baidu [Spider], ChatGPT-User, PerplexityBot, PetalBot and 4 guests
