CANBus alarm monitoring after bus recovery
ICONDev
Postby ICONDev » Mon May 31, 2021 9:21 am
we are using the can interface, idf 3.3.5 release version.
We have a seperate recovery task to get CAN alerts ant to recover from BUS_OFF. Basically we followed the recovery example, contained in the idf.
we are get the alerts properly (eg if we shorten the bus for a short moment), also the bus recovers propperly from bus of by calling the function can_initiate_recovery().
Our problem is that the event "CAN_ALERT_BUS_ERROR" is only working until the first occurence of a bus recovery. After the first recovery, the system does not report alerts like CAN_ALERT_BUS_ERROR anymore.
Reading the counters by using can_get_status_info() sows the same: info.bus_error_count counts up in case of a bus error, but after a bus-recover the counter of bus_error_count stays at its last value before the recovery happened.
A reconfiguring of the needed alerts after a bus recovery does not help.
What is wrong? Why stays the bus error counter at its position when a bus off occures and the bus recovers (and stays there till a complete restart?)
thanks for your help.
Juergen
Code snippet:
void can_recovery_task(void *arg)
ESP_LOGI(tag, "Starting CAN recovery task");
while(1)
uint32_t alerts=0;
can_read_alerts(&alerts, portMAX_DELAY);
ESP_LOGI(tag, "---Alert Read: -- : %04x", alerts);
if (alerts & CAN_ALERT_ABOVE_ERR_WARN)
ESP_LOGI(tag, "Surpassed Error Warning Limit");
if (alerts & CAN_ALERT_ERR_PASS)
ESP_LOGI(tag, "Entered Error Passive state");
if (alerts & CAN_ALERT_ERR_ACTIVE)
ESP_LOGI(tag, "Entered Can Error Active");
if (alerts & CAN_ALERT_BUS_ERROR)
ESP_LOGI(tag, "Entered Alert Bus Error");
if (alerts & CAN_ALERT_BUS_OFF)
ESP_LOGE(tag, "Bus Off --> Initiate bus recovery");
can_initiate_recovery(); //Needs 128 occurrences of bus free signal
vTaskDelay(pdMS_TO_TICKS(1000));
if (alerts & CAN_ALERT_BUS_RECOVERED)
//Bus recovery was successful
// only for testing. Does not help !!
esp_err_t res = can_reconfigure_alerts(ALERTS_ENABLED, NULL);
ESP_LOGI(tag, "Bus Recovered %d--> restarting Can", res);
//put can in start state again and re-enable alert monitoring
can_start();
ICONDev
Re: CANBus alarm monitoring after bus recovery
Postby ICONDev » Mon May 31, 2021 12:29 pm
Additionally:
if I recover the situation by completely reinstalling the driver (can_driver_uninstall() / can_driver_install()) instead of using can_initiate_recovery(), the code works propperly and the bus error counters are working as before the recovery..
This is why I assume that this is a bug in the idf can driver. (or maybe I miss something..)
Dazza0
Postby Dazza0 » Tue Jun 01, 2021 5:22 pm
@ICONDev Could it be related to the Bus Off REC errata?
A workaround for that errata has been added v4.3 and later.
Since you are on v3.3.5, could you try modifying the can_intr_handler_err_warn() in components/driver/can.c as follows and see if the issue is resolved:
Code: Untitled.c Select all
static CAN_ISR_ATTR void can_intr_handler_err_warn(can_status_reg_t *status, BaseType_t *task_woken, int *alert_req)
if (status->bus) {
if (status->error) {
//Bus-Off condition. TEC should set and held at 127, REC should be 0, reset mode entered
CAN_SET_FLAG(p_can_obj->control_flags, CTRL_FLAG_BUS_OFF);
/* Note: REC is still allowed to increase during bus-off. REC > err_warn
can prevent "bus recovery complete" interrupt from occurring. Set to
listen only mode to freeze REC. */
can_config_mode(CAN_MODE_LISTEN_ONLY);
//Re-trigger the Bus Off interrupt to clear the REC
CAN.tx_error_counter_reg.byte = 0;
CAN.tx_error_counter_reg.byte = 255;
//Clear the re-triggered interrupt
(void) can_get_interrupt_reason();
can_alert_handler(CAN_ALERT_BUS_OFF, alert_req);
//Bus-recovery in progress. TEC has dropped below error warning limit
can_alert_handler(CAN_ALERT_RECOVERY_IN_PROGRESS, alert_req);
ICONDev
Postby ICONDev » Wed Jun 02, 2021 12:52 pm
Thank you for the quick response, seems that this is the issue. I saw that there are further work arounds implemented in the current idf versions in terms of CAN.
Does Espressif intent to update the V3.x release idf with these CAN/TWAI component options (as done in the latest V3 release with the ISR IRAM option) ? Would appreciate it and would like that more than patching the component or using the current idf (which e.g means a lot of additional adaptions and testings of our complete system, also stuff like renaming can to twai and so on..).
Thank you
Juergen
Users browsing this forum: Bytespider, Qwantbot and 2 guests
