[已解决] esp-now通信不成功
wxyaoo
[已解决] esp-now通信不成功
Postby wxyaoo » Mon May 31, 2021 10:10 am
请问各位有谁玩过esp-now通信协议,是不是任何一个esp32都可以使用这个协议,目前我使用两个esp32的板子间做esp-now通信,但是一直都不通,显示peer interface is invalid,failed to add peer,也不知道什么原因。我按照官网的例子对了好几遍,都没有错,我只是改了mac地址,其他都没有动,都不行,有谁能帮分析分析吗
Gargamel
Re: esp-now通信不成功,
Postby Gargamel » Thu Jun 03, 2021 2:02 am
esp32、esp32-s、esp32-c、esp8266 之间都可以通信。你先基于原始 demo,什么都不改,跑通了再看下一步。
wxyaoo
Re: esp-now通信不成功,
Postby wxyaoo » Fri Jun 04, 2021 2:23 am
我基本都没有改,只是改了mac地址。打印出来错误为:Peer interface is invalid和Failed to add peer不懂是什么原因。是接受方哪个地方设置的不正确吗。以下是我发送端和接收端的程序,不忙的大神可以帮忙看看哪里出了问题。
以下为发送端的程序
// Own macAddress:98:F4:AB:3A:77:0C
// recver MAC Address: 98:F4:AB:39:4C:C0
#include <esp_now.h>
#include <WiFi.h>
// REPLACE WITH YOUR RECEIVER MAC Address
uint8_t broadcastAddress[] = {0x98, 0xF4, 0xAB, 0x39, 0x4C, 0xC0};
// Structure example to send data
typedef struct struct_message {
  char a[32];
  int b;
  float c;
  String d;
  bool e;
} struct_message;
// Create a struct_message called myData
struct_message myData;
// callback when data is sent
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
  Serial.print("\r\nLast Packet Send Status:\t");
  Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
  // Init Serial Monitor
  // Set device as a Wi-Fi Station
  WiFi.mode(WIFI_STA);
  Serial.println(WiFi.macAddress());
  // Init ESP-NOW
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
  // Once ESPNow is successfully Init, we will register for Send CB to
  // get the status of Trasnmitted packet
  esp_now_register_send_cb(OnDataSent);
  // Register peer
  esp_now_peer_info_t peerInfo;
  memcpy(peerInfo.peer_addr, broadcastAddress, 6);
  peerInfo.channel = 0;
  peerInfo.encrypt = false;
  // Add peer
  if (esp_now_add_peer(&peerInfo) != ESP_OK){
    Serial.println("Failed to add peer");
    return;
  // Set values to send
  strcpy(myData.a, "THIS IS A CHAR");
  myData.b = random(1,20);
  myData.c = 1.2;
  myData.d = "Hello";
  myData.e = false;
  // Send message via ESP-NOW
  esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *) &myData, sizeof(myData));
  if (result == ESP_OK) {
    Serial.println("Sent with success");
  else {
    Serial.println("Error sending the data");
    Serial.print("error code is : ");
    Serial.println(result);
  delay(2000);
以下为接受端的程序。
// send board MAC Address:98:F4:AB:3A:77:0C
// Recv board MAC Address: 98:F4:AB:39:4C:C0
#include <WiFi.h>
// Structure example to receive data
  char a[32];
  int b;
  float c;
  String d;
  bool e;
} struct_message;
// callback function that will be executed when data is received
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len) {
  memcpy(&myData, incomingData, sizeof(myData));
  Serial.print("Bytes received: ");
  Serial.println(len);
  Serial.print("Char: ");
  Serial.println(myData.a);
  Serial.print("Int: ");
  Serial.println(myData.b);
  Serial.print("Float: ");
  Serial.println(myData.c);
  Serial.print("String: ");
  Serial.println(myData.d);
  Serial.print("Bool: ");
  Serial.println(myData.e);
  Serial.println();
  // Initialize Serial Monitor
  // Init ESP-NOW
    return;
  // Once ESPNow is successfully Init, we will register for recv CB to
  // get recv packer info
  esp_now_register_recv_cb(OnDataRecv);
void loop() {  }
wxyaoo
Re: esp-now通信不成功,--现在已解决问题。
Postby wxyaoo » Fri Jun 04, 2021 3:52 am
仔细研究了esp关于wifi方面的文档,并且仔细理解了下peer interface is invalid这句话到底是哪里出错了,后来推测是不是esp-now需要指定ifidx这个参数,
wifi_interface_t ifidx:说明如下
Wi-Fi interface that peer uses to send/receive ESPNOW data
程序中是没有指定这个参数的,所以参考文档,指定了这个参数,在 peer information里面加了一句:
peerInfo.ifidx = WIFI_IF_STA;
最后测试成功了。不知道为什么很多例程都没有,反而都可以通信成功。
YAN666
Re: [已解决] esp-now通信不成功
Postby YAN666 » Sun Jun 02, 2024 12:07 pm
大佬,太感谢了。直接解决了我的问题
十八岁年天蓝
Postby 十八岁年天蓝 » Sun Dec 29, 2024 10:50 am
感谢看到你的解答,很好的解决了我的问题。
Users browsing this forum: Amazon [Bot], Bing [Bot], YisouSpider and 1 guest
