esp with alexa issue
Aaryan _02
Postby Aaryan _02 » Fri Jun 04, 2021 5:57 pm
Code: Untitled.cpp Select all
guys i need a help ,now i got esp8266 and i interfaced that to alexa so when i say turn on " " then the relay turns on but i got a new problem when i turn on the relay with alexa the power from the digital comes but the relay is not turning on (this problem i faced before and that resolved it but now i am not able to) and when i take the wire and again connect to the relay i hear some sound (tik tik) and i had given power from 5v adapter to esp from the i gave to relays and sanitizer spray machine but when i tried with ARDUINO the relays works and also i took 3v and gnd from esp and connected to another relay and that works perfect
please guys someone help me this is very important please
Re: esp with alexa issue
Postby Sprite » Sat Jun 05, 2021 7:53 am
....what? I have problems parsing your post. It looks like English, but I can't make heads or tails out of it... Can you perhaps try again, but this time in a bit more ordered fashion? For example, state clearly what hardware you have, what software you are using, the steps you're taking, the outcome you expect, and the outcome you are getting.
