High Voltage Ripple across ESP32
naitik
Postby naitik » Sat Jun 19, 2021 1:34 pm
Hello, We are designing the product based on esp32. The prototype PCB We have converts 230v > 12v > 5v > 3v3 starting from 12 Volts stage we having ripples of 14 Volts which propagated forward on Each stage of Regulator. eventually at 3v3 Stage we are getting ripple of 4.6 Volts at every 40 uS. Image
My question is that, are these short pulses of 4.6 v is tolerable ? And can anyone specify what are ways this ripples can be reduced?
thank you.
tommeyers
Re: High Voltage Ripple across ESP32
Postby tommeyers » Sat Jun 19, 2021 4:46 pm
Please post your circuit diagram with part#s
IT Professional, Maker
Santiago, Dominican Republic
Postby Sprite » Sun Jun 20, 2021 2:55 am
And to officially answer your question: 3.3V + 4.6V exceed the specs as indicated in the datasheet. It's impossible to say how the ESP32 reacts to that, but it's not officially supported and may lead to undefined behaviour.
On a sidenote: Are you sure these ripples aren't because EMI is getting into your measuring probe via e.g. the ground lead loop?
becorey
Postby becorey » Wed Jun 23, 2021 3:15 am
You could use an LDO or TVS diode to reduce the spikes. But better to look first at your 3.3v regulator, why is it passing such spikes through. Is the feedback loop node receiving noise? Is the output capacitance too low? Need to see schematic and pcb.
naitik
Postby naitik » Thu Jun 24, 2021 8:05 am
Here's Schematic :
There is 12v power supply which takes input from UK Plug 230v. the 12v power rails goes to 5v regulator then 5v goes to 3.3v then 3.3v regulator goes to 2v regulator. At each stage of conversion the Ripple voltages are propagated forward as well.
Annotation 2021-06-24 144446.png (56.52 KiB) Viewed 7641 times
Annotation 2021-06-24 144524.png (63.41 KiB) Viewed 7641 times
naitik
Postby naitik » Thu Jun 24, 2021 8:33 am
Also we are sure that Ripples are not recorded due to bad probing. because when we power the board using PC we do not get any significant amount of ripples in the oscilloscope.
Postby Sprite » Thu Jun 24, 2021 10:09 am
That doesn't tell you anything. If the board is powered by the PC, presumably the DC-DC converters are off, there's none of their EMC in the air and bad measuring won't pick it up.
naitik
Postby naitik » Thu Jun 24, 2021 12:57 pm
yea it makes sense now. i totally missed the EMI noise due to converters probably the Oscilloscope picking up some of that by providing power from pc tells basically nothing
