ESP32 LAN8720 packet loss in ping
wirahim
Postby wirahim » Sun Jun 20, 2021 10:34 am
Has anyone faced packet loss on LAN8720 if you ping from your computer? I have made an internet clock where I have used both LAN and WiFi of ESP32. Ping seems to work fine for Wi-Fi but there seems to be regular packet loss for the ethernet port.
Loss is typically less than 20%. Here is a sample:
Ping statistics for 192.168.10.189:
Packets: Sent = 602, Received = 512, Lost = 90 (14% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 15ms, Average = 0ms
Although this loss is not an issue for a clock the client is complaining about it.
Here is my configuration for the LAN8720 example code:
#define ETH_CLK_MODE ETH_CLOCK_GPIO0_OUT
// Pin# of the enable signal for the external crystal oscillator (-1 to disable for internal APLL source)
#define ETH_POWER_PIN 17
// Type of the Ethernet PHY (LAN8720 or TLK110)
#define ETH_TYPE ETH_PHY_LAN8720
// I²C-address of Ethernet PHY (0 or 1 for LAN8720, 31 for TLK110)
#define ETH_ADDR 1
// Pin# of the I²C clock signal for the Ethernet PHY
#define ETH_MDC_PIN 23
// Pin# of the I²C IO signal for the Ethernet PHY
#define ETH_MDIO_PIN 18
I have originally followed a tutorial from "https://sautter.com/blog/ethernet-on-es ... g-lan8720/". Internet works fine. I just need to solve the ping issue. Can anyone point me in the direction of a solution?
wirahim
Re: ESP32 LAN8720 packet loss in ping
Postby wirahim » Mon Jun 21, 2021 10:53 am
I found the solution. Code mentioned "possibly an inverter is needed" and I have not used any inverter. So Lan8720's internal clock source was still enabled and it was interfering with APLL's clock.
* ETH_CLOCK_GPIO0_OUT - 50MHz clock from internal APLL output on GPIO0 - possibly an inverter is needed for LAN8720
Solution:
ETH.begin(ETH_ADDR, ETH_POWER_PIN, ETH_MDC_PIN, ETH_MDIO_PIN, ETH_TYPE, ETH_CLK_MODE);
digitalWrite(ETH_POWER_PIN, LOW);
Making the power pin low after ETH.begin solves the problem if I don't use any logic level inverter. I think "possibly an inverter is needed" should be changed to "an inverter is needed".
Anyone who is reading this post, I hope this helps.
pilkyton
Postby pilkyton » Sun Jun 08, 2025 10:08 pm
I registered just to add:
You most likely just encountered the unfixable hardware bug in the ESP32, which was discovered in late 2024:
https://docs.espressif.com/projects/esp ... -wifi.html
In short:
The ESP32 50 MHz clock signal generator (PLL) completely breaks when the WiFi antenna/radio is active on the ESP32. This leads to the ESP32 hanging/freezing/dropping packets.
You cannot combine WiFi and Ethernet on the same board if you use the ESP32 as the Ethernet clock signal.
You must use a real, external crystal to be able to use WiFi + Ethernet at the same time.
