Hi, I have a google wifi router that support Wifi FTM. I found the information below in ftm example code and I don't know if I can use my ESP32-S2 as FTM initiator with external APs. Is this implemented yet? I am using ESP-IDF v4.3 stable.
"Currently FTM is only supported in below configuration:
Station as Initiator and SoftAP as Responder on supported ESP devices
Station as Initiator and an external AP that supports FTM in Responder mode The first option should be preferred since ESP devices are self calibrated for high resolution measurement. FTM Responder support for external Stations and ASAP mode will follow in future updates." -> https://github.com/espressif/esp-idf/tr ... s/wifi/ftm
Wifi FTM and external APs
Re: Wifi FTM and external APs
I flashed the example code sucefully. WIth the command scan I see all AP but the FTM support of the google wifi is not reconigsed by esp32-s2. I've got 3 google router ("Google Pisito").
ftm> scan
I (4770336) ftm_station: sta start to scan
I (4772436) ftm_station: [Google Pisito][rssi=-41]
I (4772436) ftm_station: [Google Pisito][rssi=-49]
I (4772446) ftm_station: [MIWIFI_RuGh][rssi=-57]
I (4772446) ftm_station: [MIWIFI_RuGh_EXT][rssi=-72]
I (4772456) ftm_station: [MIWIFI_2G_mKcH][rssi=-87]
I (4772456) ftm_station: [VIRGIN-telco_7470][rssi=-87]
I (4772466) ftm_station: [vodafone1244][rssi=-89]
I (4772466) ftm_station: [MOVISTAR_B612][rssi=-90]
I (4772476) ftm_station: [MiFibra-61AA][rssi=-91]
I (4772476) ftm_station: [TP-Link_C224][rssi=-91]
I (4772486) ftm_station: [vodafoneBA1465][rssi=-92]
I (4772486) ftm_station: [WIFI-1A][rssi=-92]
I (4772496) ftm_station: [TP-Link_6826][rssi=-93]
I (4772506) ftm_station: [WIFI-1B][rssi=-94]
I (4772506) ftm_station: sta scan done
ftm> ftm -I -s "Google Pisito"
I (4138426) ftm_station: Requesting FTM session with Frm Count - 32, Burst Period - 200mSec (0: No Preference)
I (4138446) ftm_station: FTM procedure with Peer(3c:28:6d:b2:e2:b4) failed! (Status - 2)
ftm> scan
According to https://people.csail.mit.edu/bkph/ftmrtt_aps Google WiFi only does FTM on the 5 GHz band, not the 2.4 GHz one. ESP32 currently only do 2.4 GHz WiFi.
