Problem - ESP32-IDF Reading HTTP-GET response with delay
slh_binary
Postby slh_binary » Thu Jun 24, 2021 9:27 am
Hi Forum,
I use the sample "http_request" from ESP-IDF V4.2 and it works. But the Problem is that when I read a file e.g 1MB from a URL, the file reading process is delayed by about 1 second every once in a while and resumes again until read the entire file. This will make the download time be long. How can to download smoothly without delay?
Re: Problem - ESP32-IDF Reading HTTP-GET response with delay
Postby Sprite » Thu Jun 24, 2021 10:05 am
What are you downloading the file to?
slh_binary
Postby slh_binary » Thu Jun 24, 2021 11:11 am
From own server and also this two links:
https://class.ece.uw.edu/542/peckol/doc ... icture.bmp
https://www.timscbx.com/Gallery%20pics/jeff%20coker.bmp
slh_binary
Postby slh_binary » Thu Jun 24, 2021 11:14 am
Both send via SPI and just showing in Terminal.
Postby Sprite » Fri Jun 25, 2021 1:35 am
Okay, that implies the one second delay can't be on the output side. Hard to say then. You could try to see if you could sniff the WiFi traffic somewhere (e.g. hotspot on a laptop + Wireshark) to see if there's obvious badness going on.
Users browsing this forum: ChatGPT-User, Qwantbot and 3 guests
