Problem - ESP32-IDF Reading HTTP-GET response with delay
Posted: Thu Jun 24, 2021 9:27 am
by slh_binary
Hi Forum,
I use the sample "http_request" from ESP-IDF V4.2 and it works. But the Problem is that when I read a file e.g 1MB from a URL, the file reading process is delayed by about 1 second every once in a while and resumes again until read the entire file. This will make the download time be long. How can to download smoothly without delay?
Re: Problem - ESP32-IDF Reading HTTP-GET response with delay
Posted: Thu Jun 24, 2021 10:05 am
by Sprite
What are you downloading the file to?
Posted: Thu Jun 24, 2021 11:11 am
by slh_binary
From own server and also this two links:
https://class.ece.uw.edu/542/peckol/doc ... icture.bmp
https://www.timscbx.com/Gallery%20pics/jeff%20coker.bmp
Posted: Thu Jun 24, 2021 11:14 am
by slh_binary
Both send via SPI and just showing in Terminal.
Posted: Fri Jun 25, 2021 1:35 am
by Sprite
Okay, that implies the one second delay can't be on the output side. Hard to say then. You could try to see if you could sniff the WiFi traffic somewhere (e.g. hotspot on a laptop + Wireshark) to see if there's obvious badness going on.
