How to set UART xon xoff characters?
zliudr
Postby zliudr » Thu Jun 24, 2021 3:12 pm
IDF V4.3 beta 1
I'm just going through the UART functions and structs. I noticed that there is a uart_sw_flowctrl_t struct that has threshold and both xon and xoff characters.
https://docs.espressif.com/projects/esp ... lowctrl_t
On the other hand, there is no function that uses this struct. The only function related is the uart_set_sw_flow_ctrl() that does NOT have the xon or xoff characters:
https://docs.espressif.com/projects/es ... _t7uint8_t
I also checked the source code. This uart_sw_flowctrl_t struct is not even defined let alone used. So is this planned, already implemented in latest or else? Thanks.
Leander
Re: How to set UART xon xoff characters?
Postby Leander » Mon Jun 13, 2022 8:37 am
The struct is used in the uart.c file when calling the SW Flow Conrol function.
esp_err_t uart_set_sw_flow_ctrl(uart_port_t uart_num, bool enable,  uint8_t rx_thresh_xon,  uint8_t rx_thresh_xoff)
    ESP_RETURN_ON_FALSE((uart_num < UART_NUM_MAX), ESP_FAIL, UART_TAG, "uart_num error");
    ESP_RETURN_ON_FALSE((rx_thresh_xon < SOC_UART_FIFO_LEN), ESP_FAIL, UART_TAG, "rx flow xon thresh error");
    ESP_RETURN_ON_FALSE((rx_thresh_xoff < SOC_UART_FIFO_LEN), ESP_FAIL, UART_TAG, "rx flow xoff thresh error");
    uart_sw_flowctrl_t sw_flow_ctl = {
        .xon_char = XON,
        .xoff_char = XOFF,
        .xon_thrd = rx_thresh_xon,
        .xoff_thrd = rx_thresh_xoff,
    UART_ENTER_CRITICAL(&(uart_context[uart_num].spinlock));
    uart_hal_set_sw_flow_ctrl(&(uart_context[uart_num].hal), &sw_flow_ctl, enable);
    UART_EXIT_CRITICAL(&(uart_context[uart_num].spinlock));
    return ESP_OK;
It doesn't mean that you can determine the xon and xoff characters.
The XON and XOFF are defined as the default ASCII characters 0x13 and 0x11 just as the UART protocol describes
#define XOFF (0x13)
#define XON (0x11)
Users browsing this forum: ChatGPT-User, PetalBot and 6 guests
