I recently designed from the ground up an ESP32 board for use in small model rockets. However, after soldering the boards I have no luck trying to program them, and due to the small QFN package I honestly can't tell if it's a soldering issue or a design issue
I can see the green Bridge TX led light up, but the Bridge RX led doesn't light up in return, meaning the ESP32 isn't responding
I made sure all the pads had paste on them before soldering, of course, but alas, I still have 3 bricked boards. I use default configuration for the ESP-IDF program besides enabling single core for the U4DW model, and I am using espressif's ESP-PROG board
Here's the schematic: https://github.com/Gip-Gip/msbaker/raw/ ... ematic.png
ESP32 No TX when programming(faulty custom board)
Re: ESP32 No TX when programming(faulty custom board)
Your schematic itself looks good to me. A few things to check:
- Does the chip get 3.3V?
- Does the 40MHz oscillator actually oscillate?
- Did you cross-connect Tx and Rx to the ESP-Prog?
- What happens if you start a terminal on the serial port and manually reset the chip?
Can confirm I didn't mix up TX and RX, ESP-TX is connected to pin 3 on the ESP-PROG and ESP-RX is connected to pin 5. Even swapped them just incase(shouldn't hurt anything) and also didn't fix my issueYour schematic itself looks good to me. A few things to check:
I'll have to wait for my oscilliscope to arrive to test to see if the 40mhz crystal is working, but until then how do I reset the chip using esp-idf or similar utilities?
Just reset it manually. You have a watchdog connected via a jumper to the EN line of the ESP32, right? Simply ground the ESP32 side of that jumper.
Gotcha, will do when I get the chanceJust reset it manually. You have a watchdog connected via a jumper to the EN line of the ESP32, right? Simply ground the ESP32 side of that jumper.
Got my oscilloscope and there was not a clock pulse at all. I have reason to suspect it's a soldering error so I've ordered another 3 prototype boards and I'll give it another shot
