Object recognition with mobilenet
ael-mess
Postby ael-mess » Thu Jul 15, 2021 9:41 am
I have been reading the open sourced documentation on GitHub of the esp-dl library.
And I would like to implement a recognition algorithm based on mobilenet, but I am not sure on how to proceed.
What does exactly
dl_matrix3d_t *dl_matrix3duf_mobilenetxx()
? is it the CNN of the model or just one depthwise separable operation? What are the steps taken in implementing the pretrained mobilenet model? And how to transfer the original weights to the ESP32?
If anyone could help I would appreciate it a lot!
Thanks,
yehangyang
Re: Object recognition with mobilenet
Postby yehangyang » Thu Jul 15, 2021 11:34 am
Hi, aei-mess
ESP-DL is under refactoring. Please follow the new ESP-DL on branch esp-dl/v2_alpha temporarily. About how to customize your own model check https://github.com/espressif/esp-dl/tre ... a/tutorial
Best Regards.
ael-mess
Postby ael-mess » Thu Jul 15, 2021 2:13 pm
Hello yehangyang,
Thank you for your fast response, good to here that the v2 of the est-dl is coming.
So you don't advise using the first release for new projects? I checked out the documentation of the v2_alpha and not all the layers are available. In my case, I will be missing the fully connected and softmax layers for the mobilenet.
Should I implement them by myself?
Regards,
