We are developing an electronic control unit that integrates your ESP-C3 module and maps the TWAI module on GPIO18 and GPIO19.
If we use GPIO18 as Rx and GPIO19 as Tx all seems good, we are able to transmit and receive CAN messages to/from the bus.If we use GPIO18 as Tx and GPIO19 as Rx, we can only transmit, but we can't see any received messages.
In the reference manual there is a NOTE:"USB - GPIO18 and GPIO19 are USB pins. The pull-up value of the two pins are controlled by the pins’pull-up value together with USB pull-up value. If any one of the pull-up value is 1, the pin’s pull-up resistorwill be enabled. The pull-up resistors of USB pins are controlled by USB_SERIAL_JTAG_DP_PULLUP"
Do we need to add some extra code to control the pin pull-up value ?Can we have more information about USB_SERIAL_JTAG_DP_PULLUP register ?
In addition we have checked in the esp-idf code and in the gpio_ll.h file, we have found this:
* The following defines are used to disable USB JTAG when pins 18 and pins 19
* are set to be used as GPIO.
* See gpio_pad_select_gpio() below.
* TODO: Delete these definitions once the USB device registers definition is
* merged.
#define USB_DEVICE_CONF0_REG (0x60043018)
#define USB_DEVICE_USB_PAD_ENABLE (BIT(14))
* @brief Select a function for the pin in the IOMUX
* @param pin_name Pin name to configure
* @param func Function to assign to the pin
static inline void gpio_ll_iomux_func_sel(uint32_t pin_name, uint32_t func)
if (pin_name == IO_MUX_GPIO18_REG || pin_name == IO_MUX_GPIO19_REG) {
CLEAR_PERI_REG_MASK(USB_DEVICE_CONF0_REG, USB_DEVICE_USB_PAD_ENABLE);
PIN_FUNC_SELECT(pin_name, func);
Adding gpio_hal_iomux_func_sel(IO_MUX_GPIO19_REG, PIN_FUNC_GPIO);before twai_driver_install(....) doesn't have an effect on the CAN.
ESP-C3 TWAI module on GPIO18 and GPIO19
Re: ESP-C3 TWAI module on GPIO18 and GPIO19
@marchino81
Try only calling before calling .
Try only calling
CLEAR_PERI_REG_MASK(USB_DEVICE_CONF0_REG, USB_DEVICE_USB_PAD_ENABLE);Code: Select all
twai_install()-
marchino81
I've tried updating esp-idf and adding
on twai self test example and I confirm that I'm able to receive on GPIO19.
But if I configure the TWAI as TWAI_MODE_NORMALMODE or TWAI_MODE_LISTEN_ONLY like:
using a real physical tranceiver connected to the board, I'm NOT able to receive the messagges on GPIO19 (The CAN analyzer indicate a Stuff Error "CAN Error RxErr ECC: 10100010, Stuff Error, Segment = ID28-ID21 " and afeter a BUS-OFF)
NOTE: Configuring RX_GPIO_NUM as GPIO4, I'm able to receive all messagges from the CAN bus.
CLEAR_PERI_REG_MASK(USB_DEVICE_CONF0_REG, USB_DEVICE_USB_PAD_ENABLE);But if I configure the TWAI as TWAI_MODE_NORMALMODE or TWAI_MODE_LISTEN_ONLY like:
static const twai_general_config_t g_config = TWAI_GENERAL_CONFIG_DEFAULT(TX_GPIO_NUM, RX_GPIO_NUM, TWAI_MODE_NORMALMODE);
static const twai_general_config_t g_config = TWAI_GENERAL_CONFIG_DEFAULT(TX_GPIO_NUM, RX_GPIO_NUM, TWAI_MODE_LISTEN_ONLY);NOTE: Configuring RX_GPIO_NUM as GPIO4, I'm able to receive all messagges from the CAN bus.
Users browsing this forum: Bing [Bot] and 2 guests
