WiFi Packet Capture Using Sniffer in ESP32
rajvrk36@gmail.com
Postby rajvrk36@gmail.com » Thu Jul 22, 2021 2:08 pm
Hardware specification: ESP32 Dev kit (Wroom).
And using ESP-MDF.
Details:
1. In promiscuous mode, the data sniffed will have a structure of header and payload.
2. If you extract this payload, you will get the WiFi data frame. This in turn have a header and payload.
3. If you extract this payload, you will get the ESP-Mesh packet. This is basically your WIFI IEEE80211 PACKET-NETWORK DATA This will
also have a header and payload which is created by ESP-MDF.
4. Our interest is this ESP-MESH header which will have the initial source MAC and final destination MAC address
So once you are able to read WIFI IEEE80211 PACKET-NETWORK DATA it will contain the ESP-MESH header.
Question:
1. Is the above understanding is correct?
2. How to decode/extract payload(PACKET-NETWORK DATA) to readable format?
Thanks for the answers :)
Best,
Rajkumar
prateekn9
Re: WiFi Packet Capture Using Sniffer in ESP32
Postby prateekn9 » Fri Jul 23, 2021 5:30 am
Your understanding is correct to extract that information you can create your own struct by looking into 802.11 standard as per your desired frame.
Take a look at this one, this repo can help you:
https://github.com/skywa04885/esp32-pac ... eee80211.h
rajvrk36@gmail.com
Postby rajvrk36@gmail.com » Wed Jul 28, 2021 2:12 pm
Hi prateekn9,
Thank you so much for the answer. We will try it out. Fingers crossed! And also some other solutions are welcomed.
Users browsing this forum: Amazon [Bot], Applebot, Bing [Bot], ChatGPT-User and 11 guests
