RS-485 half-duplex extra byte received.
sramberg2
Postby sramberg2 » Fri Jul 23, 2021 10:31 pm
IDF4.3
Sending 7 bytes out UART2 configured as RS485 Half-duplex every 80ms at 115200 baudrate.
While debugging this issue, https://www.esp32.com/viewtopic.php?f=13&t=21835
Occasionally I would see a data byte in the RX FIFO following a transmission. The byte was always 0x00.
I modified the TX DONE interrupt, in UART.c, to disable the RX FIFO flushing and I received the extra byte close to 100% of the time. It appears that the RX FIFO flush would remove this extra byte most of the time.
Code: Untitled.c Select all
        } else if(uart_intr_status & UART_INTR_TX_DONE) {
if (UART_IS_MODE_SET(uart_num, UART_MODE_RS485_HALF_DUPLEX) && uart_hal_is_tx_idle(&(uart_context[uart_num].hal)) != true) {
// The TX_DONE interrupt is triggered but transmit is active
// then postpone interrupt processing for next interrupt
uart_event.type = UART_EVENT_MAX;
// Workaround for RS485: If the RS485 half duplex mode is active
// and transmitter is in idle state then reset received buffer and reset RTS pin
// skip this behavior for other UART modes
UART_ENTER_CRITICAL_ISR(&(uart_context[uart_num].spinlock));
uart_hal_disable_intr_mask(&(uart_context[uart_num].hal), UART_INTR_TX_DONE);
if (UART_IS_MODE_SET(uart_num, UART_MODE_RS485_HALF_DUPLEX)) {
//SRR 7/23/21 uart_hal_rxfifo_rst(&(uart_context[uart_num].hal));
uart_hal_set_rts(&(uart_context[uart_num].hal), 1);
UART_EXIT_CRITICAL_ISR(&(uart_context[uart_num].spinlock));
uart_hal_clr_intsts_mask(&(uart_context[uart_num].hal), UART_INTR_TX_DONE);
xSemaphoreGiveFromISR(p_uart_obj[uart_num]->tx_done_sem, &HPTaskAwoken);
I do not see the extra byte on the output of the RS-485 driver.
Any idea on how to prevent this extra byte?
WiFive
Re: RS-485 half-duplex extra byte received.
Postby WiFive » Fri Jul 23, 2021 10:41 pm
Did you try moving it after uart_hal_set_rts
HitecSmartHome
Postby HitecSmartHome » Wed Mar 19, 2025 9:56 am
We experience the same problem. We got `0x00` byte frames on every uart. In our case these are occasional and we observe them sometimes multiple times / minute but there are cases where it isn't there for several minutes. Increasing the RX symbol timeout seems to help but it slows down the communication.
Users browsing this forum: No registered users and 12 guests
