WAP/WPA2-PSK (AES vs TKIP) with IDF 4.2.2
formus14
Postby formus14 » Mon Jul 26, 2021 12:32 pm
Quick question, I ran an example code of a wifi ap mode configured with WAP/WPA2-PSK authentication ..
But unfortunately, it seems like by default IDF uses TKIP for encryption instead of AES which is preferred for security reasons!
The question is, with the mention IDF v4.2.2 ( https://github.com/espressif/esp-idf/tree/v4.2.2 ); is it still possible to use AES instead of TKIP? what adjustment needs to be done on the code below ?
void wifi_init_softap(void)
    esp_netif_create_default_wifi_ap();
    ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT,
                                                        ESP_EVENT_ANY_ID,
                                                        &wifi_event_handler,
                                                        NULL,
                                                        NULL));
    wifi_config_t wifi_config = {
        .ap = {
            .ssid = EXAMPLE_ESP_WIFI_SSID,
            .ssid_len = strlen(EXAMPLE_ESP_WIFI_SSID),
            .channel = EXAMPLE_ESP_WIFI_CHANNEL,
            .password = EXAMPLE_ESP_WIFI_PASS,
            .max_connection = EXAMPLE_MAX_STA_CONN,
            .authmode = WIFI_AUTH_WPA_WPA2_PSK
    if (strlen(EXAMPLE_ESP_WIFI_PASS) == 0) {
        wifi_config.ap.authmode = WIFI_AUTH_OPEN;
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
    ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_AP, &wifi_config));
    ESP_ERROR_CHECK(esp_wifi_start());
    ESP_LOGI(TAG, "wifi_init_softap finished. SSID:%s password:%s channel:%d",
             EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS, EXAMPLE_ESP_WIFI_CHANNEL);
Thanks!
Users browsing this forum: Baidu [Spider], Bing [Bot], ChatGPT-User, PerplexityBot, PetalBot and 2 guests
