18650 Batteries for ESP32
au_nel
Postby au_nel » Tue Jul 27, 2021 11:14 am
Hi guys,
This is my first time doing a project with ESP32 and I really don't know what appropriate batteries/setup to use..
I use ESP32 DevKitC Nodemcu. I have three sensors connected to it: DHT22, MQ-2, and MQ-7.
Are two 18650 batteries in series enough to run it? Or do I need to step the 3.0V - 3.7V output of the series batteries to 5V??
-Nelle
Minatel
Re: 18650 Batteries for ESP32
Postby Minatel » Wed Jul 28, 2021 10:32 am
First of all, welcome to the ESP32 world!
About the battery, it will depend on the efficiency you are looking for. Usually using a single cell battery with a booster to step up to 5V with 1S charging circuit, is the easiest solution but not the perfect for energy efficiency.
For the batteries in series, you will need a 2S charging circuit and the LDO will heat (loose energy) a little bit more.
The ESP32-DevKitC is not the best solution for energy efficiency. It was designed for a generic purpose using a LDO with a dropout about 1V. This makes the dev kit not perfect for using a single cell battery on the 5V input pin, but it's possible.
Just a reminder, the ESP32 will die or will be damaged if you power with more than 3.6V directly. Do not connect 18650 battery directly on the 3V3 pin.
username
Postby username » Wed Jul 28, 2021 11:34 pm
Sounds like you might want something like this that does it all for you.
https://www.sparkfun.com/products/18018
au_nel
Postby au_nel » Mon Aug 09, 2021 11:16 am
Firstly, thanks for replying! It's my first time using this platform and I was waiting for so long for the notification button to change but it didn't and I thought no one replied to me (I realized just now how stupid this was :roll: )
I tried powering the ESP32 with two lithium AA batteries in series through both the 5V and 3V (which I just learned that I shouldn't have done. Oops.) pins directly and both did not work. This ESP32 was supposed to send the sensors' values to another ESP32 using ESP-NOW. I have been powering my ESP32 using my laptop with all the sensors tapped to the 5V pin and it was working perfectly. When I tried the series lithium AA batteries, the sensors lit up the same way it does when I was using my laptop (which I assumed means that it gets enough voltage?) but the sensors' values weren't being sent to the other ESP32.
I haven't tried using any charging circuit and its going to be the first time using one (so sorry if I'm annoying you with my cluelessness) so I guess I'll have to play with it a bit.
For the ESP32 Thing Plus C, unfortunately, I already ordered all the ESP32s I need for this project so I just have to make do with what I have..
