I am using the library for display on my AWS EduKit M5 Core2. The library works when I have uploaded some code on the board but it does not work when I upload the code after I restart the board.
https://github.com/lvgl/lv_port_esp32
I have checked weather the pin configs are correct using pinmaps on the following website
https://docs.m5stack.com/en/core/core2_for_aws
Screenshot for idf.py menuconfig.
https://ibb.co/rvMjnJN
LVGL display project for ESP32
Re: LVGL display project for ESP32
Hello @ujurmsde
my guess is that the library sample code doesn't know about the power chip (AXP192) used in M5Core2 which according to the schematic controls multiple aspects of the device including the backlight and reset of the display.
May I suggest you checkout the following example using the LVGL library which has been adapted to the M5Core2? https://github.com/ropg/m5core2_esp-idf_demo
Felix
Felix
Hi @felmue,
The library works fine.
Intially I had an issue. Then I comment out the line and it worked. I will post details latter.
../components/lvgl_esp32_drivers/lvgl_helpers.c:152:5: error: unknown type name 'spi_dma_chan_t'; did you mean 'spi_signal_conn_t'?
spi_dma_chan_t dma_chan = SPI_DMA_DISABLED;
spi_signal_conn_t
ninja failed with exit code 1
There is still some issue I am not able to figure out. For example the following code does not work in app_main()
Also, if I have saparate task to perform the given printing task, it does not work.
I tried to add the #include "core2forAWS.h" hearder and try if that works.
Core2ForAWS_Init();
Core2ForAWS_Display_SetBrightness(80);
xSemaphoreTake(xGuiSemaphore, portMAX_DELAY);
//lvgl_i2c_locking(i2c_manager_locking());
//lv_init();
//lvgl_driver_init();
lv_obj_t *label = lv_label_create(lv_scr_act(), NULL);
lv_label_set_text(label, "Drag me");
lv_obj_align(label, NULL, LV_ALIGN_CENTER, 0, 0);
// Needs to be pinned to a core
//xTaskCreatePinnedToCore(&example_obj, "gui", 4096*2, NULL, 0, NULL, 1);
printf("Running...\n");
fflush(stdout);
xSemaphoreGive(xGuiSemaphore);Who is online
