I am trying to communicate with two devices having the same I2C address, so I connected them to different gpio pairs (18,19 and 22,23).
In my code, I start the driver (i2c_driver_install), configure it (i2c_param_config) with the first pair of gpios and write 5 bytes to the bus (to the first chip).
After this I reconfigure the driver for the second pair of gpios to be used and write 5 bytes (to the second chip).
Then, I repeatedly read 5 bytes from each chip reconfiguring the driver for the right gpios.
However, I found that after the first time I reconfigure the gpios used by the I2C driver, the data appears on both pairs of gpio - previous and new. Here is the diagram taken from both gpio pairs for a reference
Could anyone tell me whether is it possible to switch pins used by I2C driver on-the-fly not to disturb other pins?
I2C doesn't work properly if reconfigure the gpios used
- 1.JPG (96.89 KiB) Viewed 7058 times
Re: I2C doesn't work properly if reconfigure the gpios used
According to https://github.com/espressif/esp-idf/bl ... #L228-L242, 0x100 is the magic number to disconnect the I2C signal from the previous pins.
eg.
I2C driver provides this to configure the new GPIOs:
eg.
// Disconnect previous
gpio_matrix_in(GPIO_NUM_18, 0x100, 0, 0);
gpio_matrix_out(GPIO_NUM_18, 0x100, 0, 0);
gpio_matrix_in(GPIO_NUM_19, 0x100, 0, 0);
gpio_matrix_out(GPIO_NUM_19, 0x100, 0, 0);
i2c_set_pin(i2c_port_t i2c_num, int sda_io_num, int scl_io_num, bool sda_pullup_en, bool scl_pullup_en, i2c_mode_t mode);Re: I2C doesn't work properly if reconfigure the gpios used
Thank you, boarchuz, your answer really help me. Currently, I can access both I2C chips correctly!
Now, I am wondering why Espressif didn't consider disconnecting the previously used Gpios upon the new pair of gpio assigning?
Thank you for asking this I2C pin question, I should have asked it a month ago.
I am preparing to release a ESP32 I2C task-safe interface with unlimited I2C buses, constrained only by available GPIO. But i2c_set_pin() didn’t work so I used i2c_config() to attach to pins and gpio_config() to release pins which worked great.
Named “sys_i2c”, it started as just a task-safe effort, but a I soon added the GPIO matrix, mutexes, and a simple configuration table for easy GPIO assignment.
I’ll upload my current code next week as is, and test with this new info.
Look for it very soon.
Burtrum
Burtrum
Hi ukrsms.Thank you, boarchuz, your answer really help me. Currently, I can access both I2C chips correctly!
May I ask how you solved your problem?
I met the same question and I tried to use Disconnect previous lines to cut the previous used pin 21/22, and signed new I2C pin: 14/15, not work.
Adam
Users browsing this forum: ChatGPT-User, Google [Bot] and 1 guest
