ESP32-C3 serial1 not working
eliott
Postby eliott » Wed Aug 11, 2021 2:29 pm
I'm trying to use the second serial port on my new ESP32-C3-WROOM-02 board.
The main port UART0 is OK and I bootload the program from Arduino IDE, and I receive debug informations.
GPIO are working well to, I only need to send data from UART1 to finish my project !
The project source is from BLE_uart code example. I only added few features because all the logic comme from BT app, but the following lines doesn't do anythings:
//header
#define RX1 2
#define TX1 3
//setup()
Serial1.begin(115200, SERIAL_8N1, RX1, TX1);
Serial1.println("BOOT");
//function
class MyCallbacks: public BLECharacteristicCallbacks {
    void onWrite(BLECharacteristic *pCharacteristic) {
      std::string rxValue = pCharacteristic->getValue();
      if (rxValue.length() >= 6)
        g_count_total_rx++;
        Serial.print("Received Value: ");
        char l_buffer[20] = {0};
        for (int i = 0; i < 6; i++)
          Serial.print(rxValue[i], DEC);
          if(i<(rxValue.length()-1)) Serial.print("-");
        Serial.println("");
        if(rxValue[0]==0xD0 && rxValue[5]==0xFF)
            g_time_deep_sleep = 5000;                             //5 secondes
            g_timer_shutdown = 0;                                 //pour mettre à jour après la déco
            Serial.println("Entering deep speel mode");           //affichage sur la console
        else
          for (int i = 0; i < 6; i++) Serial1.print(rxValue[i]);  //envoi à l'ECU
          sprintf(l_buffer, "Count %u\r\n", g_count_total_rx);
          bletx(l_buffer, strlen(l_buffer));                      //en onvoi le compre à l'appli
          Serial.print(l_buffer);                                 //affichage du comte sur la console
So with this function I'm supposed to receive the raw data from bluetooth on my serial port:
This line is supposed to send data:
I receive the decimal content on the debug port, I see message counter "Serial.print(l_buffer);"
I tested to switch RX & TX pins, monitored with FTDI device or scope. The elecical level ar OK (3V3 for TX) so the port seems to be great configured.
I use the last https://raw.githubusercontent.com/espre ... index.json lib version 2.0.0-rc1
Thank you for help.
Eliott.
eliott
Re: ESP32-C3 serial1 not working
Postby eliott » Wed Aug 11, 2021 3:39 pm
I started new projet from scratch.
With Arduino IDE this code doesn't work (GetChipID example code)
  Serial1.begin(115200,SERIAL_8N1,3,2);
  //Serial1.begin(115200,SERIAL_8N1,2,3);//tried both
	for(int i=0; i<17; i=i+8) {
	  chipId |= ((ESP.getEfuseMac() >> (40 - i)) & 0xff) << i;
	Serial.printf("ESP32 Chip model = %s Rev %d\n", ESP.getChipModel(), ESP.getChipRevision());
	Serial.printf("This chip has %d cores\n", ESP.getChipCores());
  Serial.print("Chip ID: "); Serial.println(chipId);
  Serial1.printf("ESP32 Chip model = %s Rev %d\n", ESP.getChipModel(), ESP.getChipRevision());
  Serial1.printf("This chip has %d cores\n", ESP.getChipCores());
  Serial1.print("Chip ID: "); Serial.println(chipId);
	delay(3000);
With Espressif SDK ESP32-C3, the uart_echo code works with UART 1 on PIN 2/3:
/* UART Echo Example
#include <stdio.h>
#include "freertos/task.h"
#include "driver/uart.h"
#include "driver/gpio.h"
#include "sdkconfig.h"
 * This is an example which echos any data it receives on configured UART back to the sender,
 * with hardware flow control turned off. It does not use UART driver event queue.
 * - Port: configured UART
 * - Receive (Rx) buffer: on
 * - Transmit (Tx) buffer: off
 * - Flow control: off
 * - Event queue: off
 * - Pin assignment: see defines below (See Kconfig)
#define ECHO_TEST_TXD (CONFIG_EXAMPLE_UART_TXD)
#define ECHO_TEST_RXD (CONFIG_EXAMPLE_UART_RXD)
#define ECHO_TEST_RTS (UART_PIN_NO_CHANGE)
#define ECHO_TEST_CTS (UART_PIN_NO_CHANGE)
#define ECHO_UART_PORT_NUM      (CONFIG_EXAMPLE_UART_PORT_NUM)
#define ECHO_UART_BAUD_RATE     (CONFIG_EXAMPLE_UART_BAUD_RATE)
#define ECHO_TASK_STACK_SIZE    (CONFIG_EXAMPLE_TASK_STACK_SIZE)
#define BUF_SIZE (1024)
static void echo_task(void *arg)
    /* Configure parameters of an UART driver,
     * communication pins and install the driver */
    uart_config_t uart_config = {
        .baud_rate = ECHO_UART_BAUD_RATE,
        .parity    = UART_PARITY_DISABLE,
        .flow_ctrl = UART_HW_FLOWCTRL_DISABLE,
        .source_clk = UART_SCLK_APB,
    int intr_alloc_flags = 0;
#if CONFIG_UART_ISR_IN_IRAM
    intr_alloc_flags = ESP_INTR_FLAG_IRAM;
#endif
    ESP_ERROR_CHECK(uart_driver_install(ECHO_UART_PORT_NUM, BUF_SIZE * 2, 0, 0, NULL, intr_alloc_flags));
    ESP_ERROR_CHECK(uart_param_config(ECHO_UART_PORT_NUM, &uart_config));
    ESP_ERROR_CHECK(uart_set_pin(ECHO_UART_PORT_NUM, ECHO_TEST_TXD, ECHO_TEST_RXD, ECHO_TEST_RTS, ECHO_TEST_CTS));
    // Configure a temporary buffer for the incoming data
    uint8_t *data = (uint8_t *) malloc(BUF_SIZE);
    while (1) {
        // Read data from the UART
        int len = uart_read_bytes(ECHO_UART_PORT_NUM, data, BUF_SIZE, 20 / portTICK_RATE_MS);
        // Write data back to the UART
        uart_write_bytes(ECHO_UART_PORT_NUM, (const char *) data, len);
void app_main(void)
    xTaskCreate(echo_task, "uart_echo_task", ECHO_TASK_STACK_SIZE, NULL, 10, NULL);
SDK config:
# Echo Example Configuration
CONFIG_EXAMPLE_UART_PORT_NUM=1
CONFIG_EXAMPLE_UART_BAUD_RATE=115200
CONFIG_EXAMPLE_UART_RXD=2
CONFIG_EXAMPLE_UART_TXD=3
CONFIG_EXAMPLE_TASK_STACK_SIZE=2048
# end of Echo Example Configuration
eliott
Postby eliott » Thu Aug 12, 2021 6:03 pm
Last test:
OK:
  char ltmp[20];
  sprintf(ltmp,"UART1 ready\r\n");
  uart_t* p_uart = uartBegin(0, 115200, SERIAL_8N1 , 2, 3, 100, 0, 122);
  uartWriteBuf(p_uart, (uint8_t*)ltmp, 12);
  Serial.println("Waiting a client connection to notify...");
[ 624][E][esp32-hal-cpu.c:107] addApbChangeCallback(): duplicate func=42008482 arg=3FC8D2CC<CR><LF>
UART1 ready
Waiting a client connection to notify...<CR><LF>
NOK:
char ltmp[20];
uart_t* p_uart = uartBegin(1, 115200, SERIAL_8N1 , 2, 3, 100, 0, 122);
drmpf321
Postby drmpf321 » Fri Apr 29, 2022 6:01 am
// ESP32 C3 SERIAL1  (second Uart)
   Serial1.begin(115200,SERIAL_8N1, 4,5); //int8_t rxPin=4, int8_t txPin=5
    if (Serial.available()) {      // If anything comes in Serial (USB),
    Serial1.write(Serial.read());   // read it and send it out Serial1 (pins 4 & 5)
  if (Serial1.available()) {     // If anything comes in Serial1 (pins 4 & 5)
    Serial.write(Serial1.read());   // read it and send it out Serial (USB)
works for me on ESP32 C3
calvsg88
Postby calvsg88 » Mon Jan 02, 2023 4:09 am
I'm using Arduino IDE and 'ESP32-C3-WROOM-02-N4.
I can't get UART1 no matter which pins I used.
Anyone managed to get it to work on Arduino IDE?
JeanRiegardt
Postby JeanRiegardt » Fri Aug 25, 2023 8:19 am
Hi
Sorry for the late reply. I am busy with a new design for which I have selected the ESP32-C3-WROOM-02 and need two serial ports. I found you post earlier this week. Based on it I purchased a module and built it up to test with some code I found above by drmpf321 » Fri Apr 29, 2022 8:01 am and both UART channels are working. I do use Aduino IDE 2.1.0 with "ESP32C3 Dev Module"
My circuit consists of just the module with a pull up resistor on GPIO8 and another one one the enable pin. I'm not sure about the "N4" suffix but here is the exact module I used
https://www.robotics.org.za/ESP32-C3-WR ... esp32%20c3
Users browsing this forum: Applebot and 3 guests
