ESP32-S2的芯片,IDF4.4,在menuconfig里设置CONFIG_ESPNOW_CHANNEL为13后,编译下载程序,运行后提示
E (6009) ESPNOW: Peer channel is not equal to the home channel, send fail!
Send error
[已解决] ESP-NOW修改信道到13出错
Re: ESP-NOW修改信道到13出错
叫参天没有用。
你在 esp_now_add_peer 之后,加上 esp_wifi_set_channel(peer->channel, WIFI_SECOND_CHAN_NONE);
esp-now 的发送信道需要和主信道保持一致。在 menuconfig 里配了,并没有把主信道变了,还是默认的 1。如果你要连上路由,或者是 softap,那也需要注意这个信道。
问题解决了吗?更多 ESP-NOW 的参考示例参见:https://github.com/espressif/esp-now
由于 ESP-NOW 必须和 Wi-Fi (sta or softap)处于相同的信道,你需要先设置信道与 使用 ESP-NOW 发包,参考如下:
#include <stdlib.h>
#include <time.h>
#include <string.h>
#include <assert.h>
#include "freertos/semphr.h"
#include "freertos/timers.h"
#include "nvs_flash.h"
#include "esp_event.h"
#include "esp_netif.h"
#include "esp_wifi.h"
#include "esp_log.h"
#include "esp_system.h"
#include "esp_now.h"
static const char *TAG = "espnow_example";
static uint8_t s_example_broadcast_mac[ESP_NOW_ETH_ALEN] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };
/* WiFi should start before using ESPNOW */
static void example_wifi_init(void)
ESP_ERROR_CHECK( esp_wifi_set_storage(WIFI_STORAGE_RAM) );
ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_STA) );
ESP_ERROR_CHECK( esp_wifi_start());
void app_main(void)
nvs_flash_init();
example_wifi_init();
/* Initialize ESPNOW and register sending and receiving callback function. */
ESP_ERROR_CHECK( esp_now_init() );
/* Set primary master key. */
ESP_ERROR_CHECK( esp_now_set_pmk((uint8_t *)CONFIG_ESPNOW_PMK) );
/* Add broadcast peer information to peer list. */
esp_now_peer_info_t *peer = malloc(sizeof(esp_now_peer_info_t));
memset(peer, 0, sizeof(esp_now_peer_info_t));
peer->channel = CONFIG_ESPNOW_CHANNEL;
peer->ifidx = WIFI_IF_STA;
peer->encrypt = false;
memcpy(peer->peer_addr, s_example_broadcast_mac, ESP_NOW_ETH_ALEN);
ESP_ERROR_CHECK( esp_now_add_peer(peer) );
esp_wifi_config_espnow_rate(ESP_IF_WIFI_STA, WIFI_PHY_RATE_1M_L);
uint8_t data = {0};
uint32_t timestamp_start = esp_log_timestamp();
for(int i= 0; i < 10000; ) {
if( esp_now_send(s_example_broadcast_mac, &data, sizeof(uint8_t))!= ESP_OK) {
vTaskDelay(1);
continue;
++i;
ESP_LOGI(TAG, "Time spent: %d, Frame rate: %d", esp_log_timestamp() - timestamp_start,
10000 * 1000 / (esp_log_timestamp() - timestamp_start));
free(peer);
