Open subdirectory
JVKran
Open subdirectory
Postby JVKran » Mon Aug 16, 2021 1:30 pm
Hey there!
Ok, so, I know this sounds very stupid, but I can't for the life of me figure out how to open a subdirectory. I've mounted an SD-card which I can succesfully use to play and serve files. Furthermore, I have the following function.
void list_files(const char * dirpath){
    struct dirent *ep;
    DIR *dp = opendir(dirpath);
    if (dp != NULL){
        while ((ep = readdir(dp)) != NULL) {
            ESP_LOGI(TAG, "Found %s.", ep->d_name);
        (void) closedir (dp);
        ESP_LOGE(TAG, "Failed to open directory \'%s\'!", dirpath);
When I call this function like
list_files("/sdcard/")
everything works and I'm presented with the names of all files in my terminal. Calling
list_files("/sdcard/questions")
(which is an existing directory that contains files), however, results in opendir returning a NULL-pointer.
Am I overseeing something?
Kind regards,
Jochem
Re: Open subdirectory
Postby Sprite » Tue Aug 17, 2021 1:01 am
No clue why that goes wrong, but diropen() should set errno when it returns a null pointer; can you check what that value is? (perror() may help there)
JVKran
Postby JVKran » Tue Aug 17, 2021 8:45 am
Hi there. I've now updated the function to also include the error number as below.
    struct dirent *ep;
    if (dp != NULL){
        ESP_LOGE(TAG, "Failed to open directory \'%s\'! Errno is \'%s\.'", dirpath, strerror(errno));
The error number represents 'Invalid Argument'... I imagine that not being very helpful... In the meantime, I'll go ahead and try some other SD-cards...
Kind regards,
Jochem
EDIT: Other (formatted) cards unfortunately show the exact same behaviour.
JVKran
Postby JVKran » Tue Nov 30, 2021 5:12 pm
For the record; this is still not solved and happening in the latest IDF version.
igrr
Postby igrr » Wed Dec 01, 2021 8:42 pm
Just to check, have you enabled Long File Names support for FatFS in menuconfig (e.g. CONFIG_FATFS_LFN_HEAP)? Since the directory name is longer than 8 characters, without long file names support its path will be /sdcard/questi~1 instead of /sdcard/questions.
01bffe806c
Postby 01bffe806c » Sun Jan 19, 2025 10:13 am
Sorry for the necro posting. It seems like that the path lost the '/' at the end. Try the code below.
Code: Untitled.cpp Select all
list_files("/sdcard/questions/")
Users browsing this forum: Amazon [Bot], Applebot and 4 guests
