ESP32-C3-DevKitM-1
What USB driver should be installed in Windows 10?
Windows USB driver
Re: Windows USB driver
You could try using idf-env just running the following command in Powershell:
Drivers are also part of the ESP-IDF Windows Installer
Invoke-WebRequest 'https://dl.espressif.com/dl/idf-env/idf-env.exe' -OutFile .\idf-env.exe; .\idf-env.exe driver install --espressifWho is online
