ESP32 BLE cowork with WIFI
roger_he
Postby roger_he » Thu Jun 29, 2017 9:41 am
Recently I started a project which can let BLE cowork with WIFI. So while I listen to a2dp music, I can also get web message. Till now I have some not so interesting foundings.
The BLE and wifi can be initiated by order and keep calm when no data transferring.
If there is a connection and data transferring with wifi or a2dp, seems the process will crash within one minute. From log one message shows that the wifi connection should have a problem:
[0;32mI (56606) wifi: received wifi event 5
Does any friends once worked with this case? I am not sure whether currently ESP32 wifi can not work together with BLE. :?
From a customer's perspective, as mobile phone can have BLE and WIFI work together, it will be disgusting that we need to make a choiceabout wifi mode or ble mode. Thanks for any suggestive sharing.
regards,
Roger
Re: ESP32 BLE cowork with WIFI
Postby Sprite » Fri Jun 30, 2017 12:05 am
Moved to SDK subforum.
Josegm
Postby Josegm » Sat Jul 01, 2017 9:38 am
Please note A2DP is a Bluetooth Classic profile, it's not BLE (Bluetooth Low Energy)
BLE itself works well with WiFi but I've not tried Bluetooth Classic/A2DP yet.
roger_he
Postby roger_he » Mon Jul 03, 2017 7:14 am
Hi Josegm,
Thank you for your message. I use BLE incorectly. This issue bothers me for some days and have not found the solution yet.
regards,
Users browsing this forum: Baidu [Spider], eriksl, Qwantbot, Semrush [Bot] and 2 guests
