WiFi.status() (Arduino function) alternative for esp-idf
zazas321
Postby zazas321 » Mon Sep 06, 2021 8:38 am
Hello. I use basic basic esp-idf wifi example code to connect the ESP32 device to the wifi in STA mode. Some other functions that I use require the wifi connection and I want to double check whether the device sucesfully connected to the wifi. In Arduino code, you can easily do that using WiFi.status() method, but I cannot find what would be the esp-idf alternative. Pseudo code:
if(wifi_connected_sucesfully){
	do_http_request()
else{
attemt_to_reconnect()
fasani
Contact:
Re: WiFi.status() (Arduino function) alternative for esp-idf
Postby fasani » Tue Sep 07, 2021 11:38 am
If I'm not mistaken, you can do the same having a:
bool wifiConnected = false;
And taking in account the WiFi events
you can simply set in the event that global variable:
WIFI_EVENT_STA_CONNECTED then wifiConnected = true
WIFI_EVENT_STA_DISCONNECTED then wifiConnected = false
If there is another way please enlighten me. But otherwise this just adding 3 lines and checking for the wifiConnected state.
epdiy collaborator | http://fasani.de Fan of Espressif MCUs and electronic design
microwrk234
Postby microwrk234 » Fri Nov 25, 2022 4:15 am
This works please look the attached file
station_example_to_check_wifi_connection_status.c
(2.62 KiB) Downloaded 585 times
mbratch
Postby mbratch » Sun Nov 27, 2022 12:34 am
If the example you are following is the "station" under "getting started", then just look at what the event handler is doing in that example. When a connection is made, it sets the `WIFI_CONNECTED_BIT` in the `s_wifi_event_group` event group. To determine if there's a connection, check the `WIFI_CONNECT_BIT` in that event group.
Users browsing this forum: Baidu [Spider] and 2 guests
