Installing ESP-MDF and ESP-AWS-IOT packages
gustavoledax
Postby gustavoledax » Thu Sep 09, 2021 3:45 pm
Hi everyone! I'm now using ESP-MDF on development of more robust projects involving data traffics. Recently, I've become interested on using AWS services of IoT and now I'm using IoT Core things to send data through MQTT and is working very fine.
Using mwifi and mupgrade in older projects on ESP-MDF directory works fine, the same goes to new project files where I use esp-aws-iot examples on it's default directory (by now, I've cloned both on different directories, the first beign used on User/esp/esp-mdf path and the second one on User/esp/esp-aws-iot). But now I want to use those libraries together in only one project, and I'm having some issues.
I've tried to set various EXTRA_COMPONENT_DIRS via Makefile, but it fails. I also tried to copy esp-aws-iot .h files to MDF directory and it also fails too. I think I have to do a more appropriate installation of both packages, but I have no success on searching for it on internet.
Did you guys have some thoughts about it? Thank you very much!!
Users browsing this forum: Baidu [Spider], burtrum, Bytespider, Google [Bot] and 3 guests
