As GPIO0 is a boot strapping pin can it be used as ADC?
GPIO0 as ADC
Re: GPIO0 as ADC
The only requirement for a bootstrap pin is that it has the right signal when the ESP32 boots/resets. If you can guarantee that, there's nothing stopping you from coming up with a circuit that also uses it as an ADC pin.
Re: GPIO0 as ADC
Also, keep in mind that GPIO2 is an ADC2 pin. ADC2 is not supported in ESP-IDF yet (although there is a PR made by Rudi which adds this support, which you can use as long as you don't use WiFi).
Users browsing this forum: Semrush [Bot] and 5 guests
