vscode+ESP-IDF ,After menuConfig is configured, it's stuck there.
esp-idf-vsc-ext.log
{"message":"cmake failed with exit code 1\n","stack":"Error: cmake failed with exit code 1\n\n\tat m.printError (/home/jack/.vscode/extensions/espressif.esp-idf-extension-1.2.0/dist/extension.js:1:28725)\n\tat Socket.<anonymous> (/home/jack/.vscode/extensions/espressif.esp-idf-extension-1.2.0/dist/extension.js:1:28154)\n\tat Socket.emit (events.js:315:20)\n\tat addChunk (internal/streams/readable.js:309:12)\n\tat readableAddChunk (internal/streams/readable.js:284:9)\n\tat Socket.Readable.push (internal/streams/readable.js:223:10)\n\tat Pipe.onStreamRead (internal/stream_base_commons.js:188:23)","level":"error","timestamp":"2021-09-17T08:35:28.725Z"}
{"message":"SDK Configuration editor confserver process exited with code: 2","stack":"Error: SDK Configuration editor confserver process exited with code: 2\n\tat m.printError (/home/jack/.vscode/extensions/espressif.esp-idf-extension-1.2.0/dist/extension.js:1:28725)\n\tat ChildProcess.<anonymous> (/home/jack/.vscode/extensions/espressif.esp-idf-extension-1.2.0/dist/extension.js:1:28331)\n\tat ChildProcess.emit (events.js:315:20)\n\tat Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)","level":"error","timestamp":"2021-09-17T08:35:28.757Z"}
menuconfig problem
Re: menuconfig problem
We need more information besides this.
Check troubleshooting and get the doctor command output and the SDK Configuration Editor output log
