Want to change softAP IP block
brewmstr
Postby brewmstr » Wed Sep 22, 2021 7:41 pm
How can I change the IP block used dhcps in softAP mode? The default 192.168.4.x is the same subnet used by the Amazon EERO router and is playing havoc with networking when both AP and STA modes are active.
cermak
Re: Want to change softAP IP block
Postby cermak » Fri Sep 24, 2021 4:03 pm
Hi brewmstr
Instead of creating the default wifi interface, you can create a custom one using `esp_netif_create_wifi()`
const esp_netif_ip_info_t my_subnet_ip = {
        .ip = { .addr = ESP_IP4TOADDR( 192, 168, xxx, 1) },
        .gw = { .addr = ESP_IP4TOADDR( 192, 168, xxx, 1) },
        .netmask = { .addr = ESP_IP4TOADDR( 255, 255, 255, 0) },
esp_netif_inherent_config_t cfg = ESP_NETIF_INHERENT_DEFAULT_WIFI_AP();
cfg.ip_info = & my_subnet_ip;
esp_netif_create_wifi(WIFI_IF_AP, &cfg);
esp_wifi_set_default_wifi_ap_handlers();
You can find some examples of usage in the below links to the test/sample codes of IDF:
https://github.com/espressif/esp-idf/bl ... tif.c#L249
https://github.com/espressif/esp-idf/bl ... .c#L41-L45
Users browsing this forum: ChatGPT-User and 3 guests
