regex + rtti
dontpostalot
regex + rtti
Postby dontpostalot » Mon Sep 27, 2021 8:41 am
I get linker errors when I try to use regexes with rtti enabled (by adding "build_unflags = -fno-rtti" to platformio.ini). It does link without rtti.
Here's the sketch:
#include <Arduino.h>
#include <regex>
  Serial.begin(115200, SERIAL_8N1);
      std::regex reg("man");
    if (std::regex_search("Here is my man.", reg))
        Serial.println("Matched");
    else
        Serial.println("Not matched");
  delay(1000);
And the errors:
.pio\build\esp32dev\src\main.cpp.o:(.literal._ZNSt8__detail8_ScannerIcEC5EPKcS3_NSt15regex_constants18syntax_option_typeESt6locale[std::__detail::_Scanner<char>::_Scanner(char const*, char const*, std::regex_constants::syntax_option_type, std::locale)]+0x1c): undefined reference to `typeinfo for std::ctype<char>'
.pio\build\esp32dev\src\main.cpp.o:(.literal._ZNSt8__detail8_ScannerIcEC5EPKcS3_NSt15regex_constants18syntax_option_typeESt6locale[std::__detail::_Scanner<char>::_Scanner(char const*, char const*, std::regex_constants::syntax_option_type, std::locale)]+0x20): undefined reference to `typeinfo for std::locale::facet'
*** [.pio\build\esp32dev\firmware.elf] Error 1
Any ideas?
Users browsing this forum: Google [Bot] and 6 guests
