HTTPS not working when SD card mounts
rajvrk36@gmail.com
Postby rajvrk36@gmail.com » Mon Sep 27, 2021 12:37 pm
Hardware: Thing Plus C - ESP32 WROOM with SD card.
Framework : ESP-MDF
I am working on ESP mesh. I'm using HTTPS protocol for file download and it should store at SD card.
Question:
When I mounted the SD card, I wasn't able to call the HTTPS protocol.
1. Why is this happening?
2. What should I do?
Thanks for the answers :)
Regards,
Rajkumar
Re: HTTPS not working when SD card mounts
Postby Sprite » Tue Sep 28, 2021 12:49 am
Define 'I wasn't able to call the HTTPS protocol.'? What did you try, what did you expect happened, what did happen, what log messages did it give, did any calls to functions return an error state?
