I am using ESP-WROVER-IE to communicate with an SD card using the VSPI interface. I am basically using the SD card example code from Github, with pins modified to use the default VSPI pins required for my application:
[Codebox]
#define PIN_NUM_MISO 19
#define PIN_NUM_MOSI 23
#define PIN_NUM_CLK 18
#define PIN_NUM_CS 5
[/Codebox]
When I try to adjust the frequency of the SPI communications to the SD card it seems that the ESP will only accept 20 and 40MHz. For other frequencies I configure the SPI frequency is set to 400kHz, no matter what value I feed it (apart from 20/40MHz). I configure the frequency as follows:
[Codebox]
sdmmc_host_t host = SDSPI_HOST_DEFAULT();
host.max_freq_khz = SPI_FREQ; // Overwrite default frequency from SDSPI_HOST_DEFAULT
host.slot = SD_SPI_HOST; // Overwrite default SPI host slot from HSPI to VSPI.
host.set_card_clk(host.slot, SPI_FREQ);
[/Codebox]
My sdkconfig file is attached. Any suggestions? It seems I have lost control of the clock frequency.
Issue with ESP32 SD communications using SPI for frequencies other than 20/40MHz.
- sdkconfig.zip
- sdk config for SD SPI application
- (8.46 KiB) Downloaded 371 times
Users browsing this forum: Bing [Bot] and 2 guests
