this is the first time I own such a board. I purchase 1 azdelivery esp32 devKitC esp32-WROOM-32.
I try to programm it with vscode.
To upload a program with the usb cable : is it normla, that I have to press the boot button while uploading ?
2) I try to upload OTA feature. I can upload with usb calbe, but, once it is done, ota doesn't work : it stopp at 8%. I don't know why.
Here is my code :
Here is platformIO.ino (I don't know if it's the right board !)
Code: Untitled.c Select all
; PlatformIO Project Configuration File
; Build options: build flags, source filter
; Upload options: custom upload port, speed and extra flags
; Library options: dependencies, extra library storages
; Advanced options: extra scripting
; Please visit documentation for the other options and examples
; https://docs.platformio.org/page/projectconf.html
[env:az-delivery-devkit-v4]
platform = espressif32
;board = az-delivery-devkit-v2
board = esp32dev
framework = arduino
monitor_speed = 115200
upload_protocol = esptool
upload_port = 192.168.1.117
;lib_deps = https://github.com/tzapu/WiFiManager.gitmain.cpp
#include <OTA.h>
//const char * ssid = "Routeur24";
//const char* password = "Da41ma64";
#define CONNECTION_TIMEOUT 10
Serial.println("Booting");
//************* Connexion au WIFI
IPAddress ip(192, 168, 1, 117);
IPAddress dns(192, 168, 1, 1);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
WiFi.config(ip, dns, gateway, subnet);
WiFi.begin(mySSID,myPASSWORD);
Serial.print("\nConnexion au WIFI");
int timeout_counter = 0;
while(WiFi.status() != WL_CONNECTED){
Serial.print(".");
delay(200);
timeout_counter++;
if(timeout_counter >= CONNECTION_TIMEOUT*5){
ESP.restart();
Serial.println("\nConnected to the WiFi network");
Serial.print("Local ESP32 IP: ");
//************* OTA Setup
setupOTA("TemplateSketch", mySSID, myPASSWORD);
//#ifdef defined(ESP32_RTOS) && defined(ESP32)
//#else // If you do not use FreeRTOS, you have to regulary call the handle method.
ArduinoOTA.handle();
//#endif
Serial.println("Test");
}Code: Untitled.c Select all
#ifdef ESP32
#include <WiFi.h>
#include <ESPmDNS.h>
#else
#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#endif
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#if defined(ESP32_RTOS) && defined(ESP32)
void ota_handle( void * parameter ) {
for (;;) {
delay(3500);
#endif
void setupOTA(const char* nameprefix, const char* ssid, const char* password) {
// Configure the hostname
uint16_t maxlen = strlen(nameprefix) + 7;
char *fullhostname = new char[maxlen];
uint8_t mac[6];
WiFi.macAddress(mac);
snprintf(fullhostname, maxlen, "%s-%02x%02x%02x", nameprefix, mac[3], mac[4], mac[5]);
ArduinoOTA.setHostname(fullhostname);
delete[] fullhostname;
// Configure and start the WiFi station
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
// Wait for connection
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("Connection Failed! Rebooting...");
delay(5000);
ESP.restart();
// Port defaults to 3232
// ArduinoOTA.setPort(3232); // Use 8266 port if you are working in Sloeber IDE, it is fixed there and not adjustable
// No authentication by default
// ArduinoOTA.setPassword("admin");
// Password can be set with it's md5 value as well
// MD5(admin) = 21232f297a57a5a743894a0e4a801fc3
// ArduinoOTA.setPasswordHash("21232f297a57a5a743894a0e4a801fc3");
ArduinoOTA.onStart([]() {
//NOTE: make .detach() here for all functions called by Ticker.h library - not to interrupt transfer process in any way.
String type;
if (ArduinoOTA.getCommand() == U_FLASH)
type = "sketch";
else // U_SPIFFS
type = "filesystem";
// NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
Serial.println("Start updating " + type);
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("\nAuth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("\nBegin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("\nConnect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("\nReceive Failed");
else if (error == OTA_END_ERROR) Serial.println("\nEnd Failed");
ArduinoOTA.begin();
Serial.println("OTA Initialized");
Serial.print("IP address: ");
xTaskCreate(
ota_handle, /* Task function. */
"OTA_HANDLE", /* String with name of task. */
10000, /* Stack size in bytes. */
NULL, /* Parameter passed as input of the task */
1, /* Priority of the task. */
NULL); /* Task handle. */
#endif
