Code to output master clock frequency to CLK_OUT pin?
What is some code I can use to output the master clock frequency to CLK_OUT(0) pin which is GPIO0? I am not able to find it in the programming guide, only info concerning EMAC_CLK_OUT. I want to use GPIO0 because I already have my boot mode button there and I can just probe that to get the signal as I am trying to measure the master clock frequency accurately with a frequency counter. Should this frequency reading be divided at all in code to attain an accurate output? If so how is this done? Additionally, I am using an ESP32-D0WDQ6 and not a module so I don’t have access to the other CLK_OUT pins. Also, will the output to this pin through this function produce a perfectly accurate signal of the master clock worthy of tuning the crystal with?
Re: Code to output master clock frequency to CLK_OUT pin?
I figured it out.
#include <stdio.h>
#include "driver/ledc.h"
#include "esp_err.h"
static void ledc_init(void)
ledc_timer_config_t ledc_timer = {};
ledc_timer.speed_mode = LEDC_HIGH_SPEED_MODE;
ledc_timer.timer_num = LEDC_TIMER_0;
ledc_timer.duty_resolution = LEDC_TIMER_1_BIT;
ledc_timer.freq_hz = 40000000;
ledc_timer.clk_cfg = LEDC_USE_APB_CLK;
ESP_ERROR_CHECK(ledc_timer_config(&ledc_timer));
ledc_channel_config_t ledc_channel = {};
ledc_channel.speed_mode = LEDC_HIGH_SPEED_MODE;
ledc_channel.channel = LEDC_CHANNEL_0;
ledc_channel.timer_sel = LEDC_TIMER_0;
ledc_channel.intr_type = LEDC_INTR_DISABLE;
ledc_channel.gpio_num = 0;
ledc_channel.duty = 1;
ledc_channel.hpoint = 0;
ESP_ERROR_CHECK(ledc_channel_config(&ledc_channel));
extern "C" {
void app_main() {
ledc_init();
}Who is online
Users browsing this forum: Qwantbot and 4 guests
