One of my ESP32 refuse to connect to my wifi
enitalp
Postby enitalp » Thu Jul 13, 2017 6:14 pm
I have several ESP32, all with same hardware and code. and one keep hanging at start :
E (33985) wifi: esp_wifi_get_mode 781 wifi is not init
tcpip_adapter_init
esp_event_loop_init
esp_wifi_init
I (33987) wifi: wifi firmware version: 9bf11be
I (33988) wifi: config NVS flash: enabled
I (33992) wifi: config nano formating: disabled
I (34014) wifi: Init dynamic tx buffer num: 32
I (34014) wifi: Init dynamic rx buffer num: 64
I (34015) wifi: wifi driver task: 3ffbb490, prio:23, stack:4096
I (34017) wifi: Init static rx buffer num: 10
I (34021) wifi: Init dynamic rx buffer num: 0
I (34025) wifi: Init rx ampdu len mblock:7
I (34029) wifi: Init lldesc rx ampdu entry mblock:4
I (34033) wifi: wifi power manager task: 0x3ffc424c prio: 21 stack: 2560
esp_wifi_set_storage
esp_wifi_set_mode
I (34043) Imagine: #########################******************##################################
I (34051) Imagine: Launching Wifi Connection
I (34055) Imagine: Call Start
I (34058) wifi: wifi timer task: 3ffc52c8, prio:22, stack:3584
I (34090) wifi: mode : sta (18:fe:34:6c:f5:7b)
I (34091) Imagine: Modem Mode
I (34091) wifi: sleep enable
I (34091) Imagine: Event Handler
I (34092) Imagine: ###########################################################
I (34099) Imagine: STA Start - Connect
I (34104) Imagine: ###########################################################
I (34109) wifi: type: 1
I (34111) Imagine: #########################******************##################################
I (35190) wifi: n:9 0, o:1 0, ap:255 255, sta:9 0, prof:1
I (36179) wifi: state: init -> auth (b0)
I (36681) wifi: s`À
rst:0x7 (TG0WDT_SYS_RESET),boot:0x32 (SPI_FAST_FLASH_BOOT)
configsip: 188777542, SPIWP:0x00
mode:DIO, clock div:2
load:0x3fff0008,len:8
load:0x3fff0010,len:2892
ho 0 tail 12 room 4
load:0x40078000,len:10388
load:0x40080000,len:252
entry 0x40080034
W (97) boot: PRO CPU has been reset by WDT.
W (98) boot: WDT reset info: PRO CPU PC=0x4008162c
W (98) boot: WDT reset info: APP CPU PC=0x92a807d6
No exception, nothing. tried multiple configuration (1 or 2 core) different frequencies. I can't get this one to connect.
Any idea ?
enitalp
Re: One of my ESP32 refuse to connect to my wifi
Postby enitalp » Thu Jul 13, 2017 7:51 pm
"Fixed"
I erased my flash and now my wifi works.
I flashed it with my program for the first time yesterday. unused ESP32 chip. tested it. works ok, and today no luck.
We are using 2 different wifi access point that have the same ssid, password, but one is in wpa2 the other in wpa.
Could wifi messed up with the wifi nvs calibration thinking it was the same wifi AP using wrong setting ?
I remember that previously i tried to use WIFI without NVS and it crashed all the time. Can we now disable that ?
