get-started的pipeline_tcp_client问题
SSSSJX
Postby SSSSJX » Wed Nov 10, 2021 11:13 am
请问在get-started/pipeline_tcp_client中的TCP_URL和TCP_PORT是什么啊,是自带的默认值吗,默认值编译会出错。
图二是我电脑的ip信息
HengYC
Re: get-started的pipeline_tcp_client问题
Postby HengYC » Mon Nov 15, 2021 9:15 am
你好,
Usage
Prepare the audio board:
Connect speakers or headphones to the board.
Configure the example:
Select compatible audio board in menuconfig > Audio HAL.
Set up the Wi-Fi connection by running menuconfig > Example Configuration and filling in WiFi SSID , WiFi Password CONFIG_TCP_URL and CONFIG_TCP_PORT.
Load and run the example:
Copy a mp3 music to tools folder, and named esp32.mp3
Run the tcp_server_write.py script from tools folder
The audio board will first connect to the Wi-Fi.
Then the board will get data from local server and play
此例程的 README 已经提供了详细是使用步骤, 关于你说的这两个参数应该是 tcp_server_write.py 脚本运行时候提供的参数,IP 地址需要实际确定。
Users browsing this forum: YisouSpider and 1 guest
