heap_caps_malloc() returning NULL on spiram
Baldhead
Postby Baldhead » Mon Nov 22, 2021 5:31 pm
I am trying to allocate some memory from spiram, but heap_caps_malloc() is returning null.
What's the problem ?
In chip esp32-s3 is possible allocate dma memory from spiram !!!
chip: esp32-s3
chip revision: 0
ESP-ROM:esp32s3-20210327
idf version: v4.4-dev-3675-g35b20cadce
menuconfig: make ram allocatable using heap_caps_malloc(..., MALLOC_CAP_SPIRAM)
board: * ESP32-S3-DevKitC-1
* esp32-s3-wroom-1 D2N8R8
uint16_t* p_buffer_a = (uint16_t*) heap_caps_malloc( 307200, MALLOC_CAP_8BIT | MALLOC_CAP_DMA | MALLOC_CAP_SPIRAM );
uint16_t* p_buffer_b = (uint16_t*) heap_caps_malloc( 307200, MALLOC_CAP_8BIT | MALLOC_CAP_DMA | MALLOC_CAP_SPIRAM );
if( p_buffer_a == NULL || p_buffer_b == NULL )
    if( p_buffer_a == NULL )    ESP_LOGI("TAG", "p_buffer_a == NULL");
    if( p_buffer_b == NULL )    ESP_LOGI("TAG", "p_buffer_b == NULL");
Thank's.
WiFive
Re: heap_caps_malloc() returning NULL on spiram
Postby WiFive » Mon Nov 22, 2021 9:56 pm
I think dma is able to access spiram but it is not considered to be "dma ram" so try taking out MALLOC_CAP_DMA
Baldhead
Postby Baldhead » Wed Nov 24, 2021 6:04 pm
Hi @WiFive,
Now "heap_caps_malloc()" dont returned null.
uint16_t* p_buffer_a = (uint16_t*) heap_caps_malloc( 307200, MALLOC_CAP_8BIT | MALLOC_CAP_SPIRAM );
Won't i have problems accessing the spiram with dma this way ?
Thank's.
WiFive
Postby WiFive » Wed Nov 24, 2021 6:41 pm
The EDMA hardware feature allows DMA buffers to be placed in external PSRAM, but there may be additional alignment constraints. Consult the {IDF_TARGET_NAME} Technical Reference Manual for details. To allocate a DMA-capable external memory buffer, use the ``MALLOC_CAP_SPIRAM`` capabilities flag together with :cpp:func:`heap_caps_aligned_alloc` with the necessary alignment specified.
Baldhead
Postby Baldhead » Thu Nov 25, 2021 11:45 pm
Hi @WiFive,
Why p_buffer_b are returning null if the internal memory capacity are 512kB ?
What the capacity made available by esp-idf or hardware limit for heap_caps_malloc( ? , MALLOC_CAP_8BIT | MALLOC_CAP_DMA | MALLOC_CAP_INTERNAL) ?
uint16_t* p_buffer_a = (uint16_t*) heap_caps_malloc( 76800, MALLOC_CAP_8BIT | MALLOC_CAP_DMA | MALLOC_CAP_INTERNAL );
uint16_t* p_buffer_b = (uint16_t*) heap_caps_malloc( 76800, MALLOC_CAP_8BIT | MALLOC_CAP_DMA | MALLOC_CAP_INTERNAL );
Thank's.
Postby Sprite » Fri Nov 26, 2021 1:13 am
Possibly because your memory is fragmented: there is no continuous chunk of free memory of that size available for the allocator to return. (Also note that obviously other things will eat into the 512K of RAM available as well.)
levente
Postby levente » Fri Nov 26, 2021 10:56 am
Would concur, the problem was/is most likely that with the specific capabilities (especially DMA) *and* large requested size, the pool had no such allocation class available.
So with heap allocations, even thought the physical maximum size of available heap is larger than what is being requested, depending on the heap manager and the allocation classes + their availability at time of alloc, it may say it cannot allocate requested lump.
This granularity is used to manage, as much as possible, heap fragmentation - so it is never a single amorphous huge lump of memory.
Baldhead
Postby Baldhead » Fri Nov 26, 2021 4:37 pm
I would like to know how much internal memory is available for dynamic allocation provided by esp-idf in esp32-s3.
I would like to know how much internal memory is available for dma in esp32-s3 too.
I remember that in esp32 there was a limit in esp-idf (i think it was for static allocation), 192kB if i'm not mistaken.
Baldhead
Postby Baldhead » Fri Nov 26, 2021 7:20 pm
no information about dma capable memory.
"All" internal ram is dma capable ?
1kB, 2kB, 100kB..... ?
Users browsing this forum: ChatGPT-User, PerplexityBot and 19 guests
