Checking GPIO level in ULP on the ESP32S2
DylanWork
Postby DylanWork » Tue Nov 23, 2021 2:13 pm
Hi all,
I am currently stuck trying to understand what is happening with my code in ULP.
I am using an IRLED and phototransistor combo to detect entry events using the ULP.
I originally used this example:
https://github.com/espressif/esp-idf/tr ... riscv/gpio
Which puts the ULP processor into an infinite while loop until the wakeup function is called.
I have now begun utilising the ULP without the infinite while loop like this new example:
https://github.com/espressif/esp-idf/tr ... 20_onewire
However, now that I turn the ULP off and on every 300ms, it appears that the pin config is incorrect after the first reset (assumption, unlikely true, the real change is explained below).
Example:
Code: Untitled.c Select all
[code]
for(int i = 13; i < 17; ++i){ //cycle through GPIO's 13 to 16
wait(2000); //Keep LED's off for 1000 cycles
example_ulp_gpio_init(i); //Init LED Pin
example_ulp_gpio_output_enable(i); //Set LED pin as input/drain
example_ulp_gpio_set_output_mode(i, 1); //Set LED output to high
wait(2000); //Keep LED on for 2000 cycles
gpio_level = (bool)example_ulp_gpio_get_level(GPIO_NUM_21); //Check level of Phototransistor
if((bool)example_ulp_gpio_get_level(GPIO_NUM_21))
{ //If phototransistor level is 1 - an LED is being blocked
yellow_heartbeat();
wait(6000); //Keep LED on for 6000 cycles
example_ulp_gpio_output_disable(i);
example_ulp_gpio_deinit(i);
[/code]
This code while in the infinite while loop works everytime.
However without the infinite while loop it works the first time the gpio_level is changed and then never again.
It seems as though I need setup the GPIO lines at the beginning of the main loop, I have tried this:
[Codebox=c file=Untitled.c]
   example_ulp_gpio_init(GPIO_NUM_21);
    example_ulp_gpio_input_enable(GPIO_NUM_21);
    example_ulp_gpio_pulldown_disable(GPIO_NUM_21);
    example_ulp_gpio_pullup_disable(GPIO_NUM_21);
[/Codebox]
But no progress as of yet.
I hope I've explained this issue well enough.
I have searched the forums and the datasheet to understand how to configure the pins in ULP but I'm falling short of a solution.
Using the get_level function in ULP seems like a pretty straight forward process, so I'm not understanding where I could be going wrong, hopefully it's something simple that I've missed...
Any help is greatly appreciated,
Cheers
DylanWork
Re: Checking GPIO level in ULP on the ESP32S2
Postby DylanWork » Wed Nov 24, 2021 1:33 pm
Hi all,
To give a clear example of the issue occurring here.
This code does not work:
int main (void)
    for(int i = 13; i < 17; ++i){                                    //Cycle through IRLED GPIO's
        wait(2000);                                                     //Keep LED's off for 2000 cycles
        while((bool)example_ulp_gpio_get_level(Phototransistor))
            yellow_heartbeat(); //The Yellow LED should blink when the path between the IRLED and the Phototransistor is blocked
        // wait(1000);
This code does work:
int main (void)
while(1){
        // wait(1000);
The setup between these two functions are exactly the same, I just wrap the for loop with the while(1) loop.
This is how I have come to the conclusion that something happens to the GPIO setup when the ULP goes to sleep for 300ms as setup here:
static void init_ulp_program(void)
    esp_err_t err = ulp_riscv_load_binary(ulp_main_bin_start, (ulp_main_bin_end - ulp_main_bin_start));
    ESP_ERROR_CHECK(err);
    /* The first argument is the period index, which is not used by the ULP-RISC-V timer
     * The second argument is the period in microseconds, which gives a wakeup time period of: 20ms
    ulp_set_wakeup_period(0, 300000);
    /* Start the program */
    err = ulp_riscv_run();
I hope this gives more clarity to the issue.
How do I continue to check the status of a GPIO in ULP mode?
deandob
Postby deandob » Thu Nov 25, 2021 7:45 am
Dylan,
If I understand you correctly, you are looking for confirmation that with the ESP32-S2:
1) When the ULP wakes up from sleep, it has to re-initialize all the pin settings?
2) Re-initializing the pin settings after ULP wake-up works the first time but not for subsequent wake-ups (the pins are back to the default state).
I don't think both 1 and 2 are expected behaviors, maybe someone from the Espressif team can confirm? And if not, its likely a logic error in your software.
Users browsing this forum: No registered users and 9 guests
