Is it possible to use the video stream from a CCTV surveillance system instead of camera?
lukecam95
Postby lukecam95 » Fri Dec 10, 2021 11:14 am
Basically the question is in the title: Is it possible to use an existing video stream from a CCTV surveillance system instead of camera and implement facial detection on it using ESP-WHO?
Thank you for your time.
Regards,
Luke
Sandra
Re: Is it possible to use the video stream from a CCTV surveillance system instead of camera?
Postby Sandra » Mon Dec 13, 2021 4:34 am
Theoretically, yes! You may try input surveillance images (RGB888 or RGB565) to the interface of face detection model.
But maybe you need to check image quality first, if it's wide-view/high-resolution, the detection performance might be affected, e.g. delay might be long.
