Auto Reconnect to Station without disconnecting AP
esp1979
Postby esp1979 » Mon Dec 20, 2021 7:19 am
my sketch uses WIFI_AP_STA as WiFi mode.
The AP setup works fine, but the connection to the station is sometimes lost.
As I know by now, unlike the ESP8266, the ESP32 does not then automatically connect to the station after losing the wifi connection.
So I wonder: what is the correct way to re-trigger the connection with the station?
I often read that a reboot would be the best way or this way:
wifi.disconnect();
wifi.begin();
or
wifi.disconnect();
wifi.reconnect();
But:
If I do a WiFi.disconnect(), my AP will also be terminated, right?
And I want to keep the AP always up and reconnect only the STA.
So I decided to use this variant:
if (WiFi.status() != WL_CONNECTED) {
      if (millis() - reconnmillis > reconn_timer) {
        WiFi.begin(ssid, password);
        unsigned long pause=5000;
        unsigned long connTimer = millis();
        while (WiFi.status() != WL_CONNECTED && (millis()-connTimer < pause)) {
          delay(500);
          yield();
        reconnmillis = millis();
Is this ok or is it bad to use a Wifi.begin() without a previous Wifi.disconnect()?
Thanks already for your help
Best wishes
Daniel
esp1979
Re: Auto Reconnect to Station without disconnecting AP
Postby esp1979 » Tue Dec 21, 2021 7:34 pm
Is there really no one that can help me? ;-(
Please...
MakerMan
Postby MakerMan » Thu Dec 23, 2021 3:17 pm
I don't have a definitive answer, but a couple of thoughts which might stimulate some debate ...
Have you tried the options "WiFi.setAutoReconnect(true) and WiFi.persistent(true) to see if that will force auto-reconnect?
Did WiFi.reconnect() not work? Was that why you're looking at WiFi.disconnect() followed by WiFi.begin(ssid, password)?
esp1979
Postby esp1979 » Sat Dec 25, 2021 7:09 pm
WiFi.setAutoReconnect(true) does the job, perfect.
I set WiFi.persistent(false) so that ESP does not write ssid and password to flash on every connect.
Best wishes and merry christmas.
Daniel
Users browsing this forum: ChatGPT-User, Google [Bot], PetalBot and 5 guests
