***ERROR*** A stack overflow in task main has been detected.
senudajayalath
Postby senudajayalath » Sat Dec 25, 2021 4:48 pm
I am trying to send data through espnow. This is my code
Code: Untitled.c Select all
/* ESPNOW Example
This example shows how to use ESPNOW.
Prepare two device, one for sending ESPNOW data and another for receiving
ESPNOW data.
#include <stdlib.h>
#include <time.h>
#include <string.h>
#include <assert.h>
#include "freertos/semphr.h"
#include "freertos/timers.h"
#include "nvs_flash.h"
#include "esp_event.h"
#include "esp_netif.h"
#include "esp_wifi.h"
#include "esp_log.h"
#include "esp_system.h"
#include "esp_now.h"
#include "esp_crc.h"
#include "espnow_example.h"
#define ESPNOW_MAXDELAY 512
typedef enum
EXAMPLE_ESPNOW_SEND_CB,
EXAMPLE_ESPNOW_RECV_CB,
} example_espnow_event_id_t;
typedef struct
uint8_t mac_addr[ESP_NOW_ETH_ALEN];
esp_now_send_status_t status;
} example_espnow_event_send_cb_t;
typedef struct
uint8_t *data;
int data_len;
} example_espnow_event_recv_cb_t;
typedef union
example_espnow_event_send_cb_t send_cb;
example_espnow_event_recv_cb_t recv_cb;
} example_espnow_event_info_t;
/* When ESPNOW sending or receiving callback function is called, post event to ESPNOW task. */
typedef struct
example_espnow_event_id_t id;
example_espnow_event_info_t info;
} example_espnow_event_t;
/* User defined field of ESPNOW data in this example. */
typedef struct
uint8_t type; //Broadcast or unicast ESPNOW data.
uint8_t state; //Indicate that if has received broadcast ESPNOW data or not.
uint16_t seq_num; //Sequence number of ESPNOW data.
uint16_t crc; //CRC16 value of ESPNOW data.
uint32_t magic; //Magic number which is used to determine which device to send unicast ESPNOW data.
uint32_t payload[0]; //Real payload of ESPNOW data.
} __attribute__((packed)) example_espnow_data_t;
/* Parameters of sending ESPNOW data. */
typedef struct
bool unicast; //Send unicast ESPNOW data.
bool broadcast; //Send broadcast ESPNOW data.
uint16_t count; //Total count of unicast ESPNOW data to be sent.
uint16_t delay; //Delay between sending two ESPNOW data, unit: ms.
int len; //Length of ESPNOW data to be sent, unit: byte.
uint8_t *buffer; //Buffer pointing to ESPNOW data.
uint8_t dest_mac[ESP_NOW_ETH_ALEN]; //MAC address of destination device.
} example_espnow_send_param_t;
static const char *TAG = "espnow_example";
static xQueueHandle s_example_espnow_queue;
static uint8_t s_example_broadcast_mac[ESP_NOW_ETH_ALEN] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
static uint16_t s_example_espnow_seq[EXAMPLE_ESPNOW_DATA_MAX] = {0, 0};
static void example_espnow_deinit(example_espnow_send_param_t *send_param);
/* WiFi should start before using ESPNOW */
static void example_wifi_init(void)
ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
ESP_ERROR_CHECK(esp_wifi_set_mode(ESPNOW_WIFI_MODE));
ESP_ERROR_CHECK(esp_wifi_start());
#if CONFIG_ESPNOW_ENABLE_LONG_RANGE
ESP_ERROR_CHECK(esp_wifi_set_protocol(ESPNOW_WIFI_IF, WIFI_PROTOCOL_11B | WIFI_PROTOCOL_11G | WIFI_PROTOCOL_11N | WIFI_PROTOCOL_LR));
#endif
/* ESPNOW sending or receiving callback function is called in WiFi task.
* Users should not do lengthy operations from this task. Instead, post
* necessary data to a queue and handle it from a lower priority task. */
static void example_espnow_send_cb(const uint8_t *mac_addr, esp_now_send_status_t status)
example_espnow_event_t evt;
example_espnow_event_send_cb_t *send_cb = &evt.info.send_cb;
if (mac_addr == NULL)
ESP_LOGE(TAG, "Send cb arg error");
return;
evt.id = EXAMPLE_ESPNOW_SEND_CB;
memcpy(send_cb->mac_addr, mac_addr, ESP_NOW_ETH_ALEN);
send_cb->status = status;
if (xQueueSend(s_example_espnow_queue, &evt, ESPNOW_MAXDELAY) != pdTRUE)
ESP_LOGW(TAG, "Send send queue fail");
int example_espnow_data_parse(uint8_t *data, uint16_t data_len) //int example_espnow_data_parse(uint8_t *data, uint16_t data_len, uint8_t *state, uint16_t *seq, int *magic)
example_espnow_data_t *buf = (example_espnow_data_t *)data;
uint16_t crc, crc_cal = 0;
if (data_len < sizeof(example_espnow_data_t))
ESP_LOGE(TAG, "Receive ESPNOW data too short, len:%d", data_len);
return -1;
// *state = buf->state;
// *seq = buf->seq_num;
// *magic = buf->magic;
crc = buf->crc;
buf->crc = 0;
crc_cal = esp_crc16_le(UINT16_MAX, (uint8_t const *)buf, data_len);
ESP_LOGI(TAG, "This is seq_num:%d", buf->seq_num);
ESP_LOGI(TAG, "This is data:%u", buf->payload[0]);
ESP_LOGI(TAG, "This is data:%u", buf->payload[1]);
ESP_LOGI(TAG, "This is data:%u", buf->payload[2]);
ESP_LOGI(TAG, "This is data:%u", buf->payload[3]);
ESP_LOGI(TAG, "This is data:%u", buf->payload[4]);
ESP_LOGI(TAG, "This is magic:%d", buf->magic);
if (crc_cal == crc)
return buf->type;
return -1;
static void example_espnow_recv_cb(const uint8_t *mac_addr, const uint8_t *data, int len)
example_espnow_event_recv_cb_t *recv_cb = &evt.info.recv_cb;
if (mac_addr == NULL || data == NULL || len <= 0)
ESP_LOGE(TAG, "Receive cb arg error");
return;
evt.id = EXAMPLE_ESPNOW_RECV_CB;
memcpy(recv_cb->mac_addr, mac_addr, ESP_NOW_ETH_ALEN);
recv_cb->data = malloc(len);
if (recv_cb->data == NULL)
ESP_LOGE(TAG, "Malloc receive data fail");
return;
//ESP_LOGE(TAG, "This is data:%u", *data);
memcpy(recv_cb->data, data, len);
recv_cb->data_len = len;
// if (xQueueSend(s_example_espnow_queue, &evt, ESPNOW_MAXDELAY) != pdTRUE)
// ESP_LOGW(TAG, "Send receive queue fail");
// free(recv_cb->data);
ESP_LOGI(TAG, "DATA HEREEE");
ESP_LOGI(TAG, "Receiveth broadcast data from: " MACSTR ", len: %d", MAC2STR(recv_cb->mac_addr), recv_cb->data_len);
int ret = example_espnow_data_parse(recv_cb->data, recv_cb->data_len);
// int ret = example_espnow_data_parse(recv_cb->data, recv_cb->data_len);
/* Parse received ESPNOW data. */
/* Prepare ESPNOW data to be sent. */
void example_espnow_data_prepare(example_espnow_send_param_t *send_param)
example_espnow_data_t *buf = (example_espnow_data_t *)send_param->buffer;
assert(send_param->len >= sizeof(example_espnow_data_t));
buf->type = IS_BROADCAST_ADDR(send_param->dest_mac) ? EXAMPLE_ESPNOW_DATA_BROADCAST : EXAMPLE_ESPNOW_DATA_UNICAST;
buf->state = send_param->state;
buf->seq_num = s_example_espnow_seq[buf->type]++;
buf->crc = 0;
buf->magic = send_param->magic;
buf->payload[0] = 3423; //data_Array[0]; // identifier that reader moved to new tree
buf->payload[1] = 454; //data_Array[1]; //old tree id
buf->payload[2] = 354; //data_Array[2]; //new tree id
buf->payload[3] = 654; //data_Array[3]; //fruit1
buf->crc = esp_crc16_le(UINT16_MAX, (uint8_t const *)buf, send_param->len);
static void example_espnow_task(void *pvParameter)
uint8_t recv_state = 0;
uint16_t recv_seq = 0;
int recv_magic = 0;
bool is_broadcast = false;
int ret;
vTaskDelay(5000 / portTICK_RATE_MS);
ESP_LOGI(TAG, "Start sending broadcast data");
/* Start sending broadcast ESPNOW data. */
example_espnow_send_param_t *send_param = (example_espnow_send_param_t *)pvParameter;
if (esp_now_send(send_param->dest_mac, send_param->buffer, send_param->len) != ESP_OK)
ESP_LOGE(TAG, "Send error");
example_espnow_deinit(send_param);
vTaskDelete(NULL);
vTaskDelay(send_param->delay / portTICK_RATE_MS);
vTaskDelete(NULL);
esp_err_t send_data()
example_espnow_send_param_t *send_param;
/* Initialize sending parameters. */
send_param = malloc(sizeof(example_espnow_send_param_t));
memset(send_param, 0, sizeof(example_espnow_send_param_t));
if (send_param == NULL)
ESP_LOGE(TAG, "Malloc send parameter fail");
vSemaphoreDelete(s_example_espnow_queue);
esp_now_deinit();
return ESP_FAIL;
send_param->unicast = false;
send_param->broadcast = true;
send_param->state = 0;
send_param->magic = esp_random();
send_param->count = CONFIG_ESPNOW_SEND_COUNT;
send_param->delay = CONFIG_ESPNOW_SEND_DELAY;
send_param->len = 18; //CONFIG_ESPNOW_SEND_LEN;
send_param->buffer = malloc(18);
if (send_param->buffer == NULL)
ESP_LOGE(TAG, "Malloc send buffer fail");
free(send_param);
esp_now_deinit();
return ESP_FAIL;
memcpy(send_param->dest_mac, s_example_broadcast_mac, ESP_NOW_ETH_ALEN);
example_espnow_data_prepare(send_param);
ESP_LOGI(TAG, "Came heree");
xTaskCreate(example_espnow_task, "example_espnow_task", 2048, send_param, 4, NULL);
return ESP_OK;
free(send_param->buffer);
free(send_param);
esp_now_deinit();
static void example_espnow_init(void)
s_example_espnow_queue = xQueueCreate(ESPNOW_QUEUE_SIZE, sizeof(example_espnow_event_t));
if (s_example_espnow_queue == NULL)
ESP_LOGE(TAG, "Create mutex fail");
return ESP_FAIL;
/* Initialize ESPNOW and register sending and receiving callback function. */
ESP_ERROR_CHECK(esp_now_init());
ESP_ERROR_CHECK(esp_now_register_send_cb(example_espnow_send_cb));
ESP_ERROR_CHECK(esp_now_register_recv_cb(example_espnow_recv_cb));
/* Set primary master key. */
ESP_ERROR_CHECK(esp_now_set_pmk((uint8_t *)CONFIG_ESPNOW_PMK));
/* Add broadcast peer information to peer list. */
esp_now_peer_info_t *peer = malloc(sizeof(esp_now_peer_info_t));
if (peer == NULL)
ESP_LOGE(TAG, "Malloc peer information fail");
esp_now_deinit();
return ESP_FAIL;
memset(peer, 0, sizeof(esp_now_peer_info_t));
peer->channel = CONFIG_ESPNOW_CHANNEL;
peer->ifidx = ESPNOW_WIFI_IF;
peer->encrypt = false;
memcpy(peer->peer_addr, s_example_broadcast_mac, ESP_NOW_ETH_ALEN);
ESP_ERROR_CHECK(esp_now_add_peer(peer));
free(peer);
void app_main()
example_wifi_init();
example_espnow_init();
send_data();
I am able to send data using espnow by writing the data to be sent to "buf" in the function "example_espnow_data_prepare". But the thing is when I increase the number of data to be sent this error comes up .( Here increasing the number of data means increasing the length of "buf" array
    buf->payload[4] =34;
    buf->payload[5] = 564;
This is the error
I have seen from similar questions that this comes up because of not having the required stack depth. But increasing the value 2048 here
doesn't solve the problem. I even tried using 30,000.
Any suggestion would be really helpful. Thankss in advance
Re: ***ERROR*** A stack overflow in task main has been detected.
Postby Sprite » Sun Dec 26, 2021 2:57 am
Increasing the stack there does not help as it's not the task which stack is overflowing; per the error message, it's the 'main' task stack that is the problem. You can adjust the stack it gets in menuconfig.
senudajayalath
Postby senudajayalath » Sun Dec 26, 2021 4:43 am
Where can I find the menuconfig in my project. There doesn't seem to be any menuconfig file in the project. And how can I adjust the stack it gets. Can you please explain that as well. Thank you.
chegewara
Postby chegewara » Sun Dec 26, 2021 6:18 am
I think the error is misleading and here is your error:
senudajayalath
Postby senudajayalath » Sun Dec 26, 2021 9:59 am
Thank you very much. That solved the problem
smit.italiya
Postby smit.italiya » Fri Feb 14, 2025 12:54 pm
#include <stdio.h>
#include "driver/gpio.h"
#include "freertos/task.h"
#include "esp_mac.h"
#define TAG "FreeRTOS"
// define the gpio that is used as common between two tasks
#define LED 2 //at gpio 2
uint16_t state = 0;
void Task_1(void *);
void Task_2(void *);
SemaphoreHandle_t semaphore = NULL;
void app_main(void)
semaphore = xSemaphoreCreateBinary(); // semaphore creation
BaseType_t xReturned;
//setting the gpio parameter
gpio_reset_pin(LED);
gpio_set_direction(LED,GPIO_MODE_OUTPUT);
ESP_LOGI(TAG, "Creating The Task!!");
xReturned = xTaskCreate(Task_1,"TASK1",256,NULL,1,NULL);
if(xReturned == pdPASS)
ESP_LOGI(TAG, "TASK 1 CREATED!!");
vTaskDelay(1);
xReturned = xTaskCreate(Task_2,"TASK2",256,NULL,1,NULL);
ESP_LOGI(TAG, "TASK 2 CREATED!!");
vTaskDelay(1);
ESP_LOGI(TAG, "Start the Scheduler!!");
vTaskStartScheduler();
while(1) {
ESP_LOGI(TAG, "While loop!!");
//nothing to do
//defining tasks
void Task_1(void *b) {
while(1) {
xSemaphoreTake(semaphore,portMAX_DELAY);
ESP_LOGI(TAG, "Turning ON LED From Task_1");
gpio_set_level(LED,true);
vTaskDelay(1000/portTICK_PERIOD_MS);
xSemaphoreGive(semaphore);
void Task_2(void *b) {
while(1) {
ESP_LOGI(TAG, "Turning OFF LED From Task_2");
gpio_set_level(LED,false);
Got the error and rebooting esp32 again and again
***ERROR*** A stack overflow in task TASK1 has been detected.
can you help me with this?
Bryght-Richard
Postby Bryght-Richard » Fri Feb 14, 2025 7:42 pm
@smit.italiya, I forget if xTaskCreate() takes bytes or 32-bit words for uxStackDepth parameter, but 256 of either might not be enough for ESP_LOG, which supports var-arg string formatting. Try increasing your stack depth for those threads.
smit.italiya
Postby smit.italiya » Sat Feb 15, 2025 4:32 am
#define configSTACK_DEPTH_TYPE uint32_t
it takes uint32_t ,so we can say that 256 bytes is enough for esp_logi also i tried with increasing the stack size by 1024 but got the same output. anything else did i wrong in the code?
chegewara
Postby chegewara » Sat Feb 15, 2025 7:09 am
Actually not. Espressif version freertos we are using is using uint8 in stack depth.
Small tip here:
- minimum stack size is 1500-2000
- with logs, printf, sprintf etc its safe to start with stack size 3500-4000
smit.italiya
Postby smit.italiya » Sat Feb 15, 2025 9:22 am
Small tip here:
Thanks for your tip after increasing stack size more than enough as you suggest go up to 4000 i got another error
***ERROR***
E (15317) task_wdt: Task watchdog got triggered. The following tasks/users did not reset the watchdog in time:
E (15317) task_wdt: - IDLE0 (CPU 0)
E (15317) task_wdt: Tasks currently running:
E (15317) task_wdt: CPU 0: main
E (15317) task_wdt: CPU 1: IDLE1
E (15317) task_wdt: Print
CPU 0 (current core) backtrace
then i searched online and found one solution that guy suggested not to set watchdog for IDEAL task of core 0 and 1 from menuconfig.
it is okay to do that ? bcz after doing this i did not get any error on Monitor window.
Users browsing this forum: No registered users and 6 guests
