Page 1 of 2
OpenOCD installation issues, can't find 'esp108'
Posted: Sun Jul 23, 2017 6:15 pm
by justinmreina
I am getting started on my ESP32 development and have just installed OpenOCD. I can't seem to access to esp108, see attached. What is the issue here, how to resolve? I am guessing it is not built in the OpenOCD directory (~/esp/openocd-esp32/), or it is not on PATH.
Re: OpenOCD installation issues, can't find 'esp108'
Posted: Sun Jul 23, 2017 7:29 pm
by krzychb
Hi justinmreina,
I do not see the command you have used to call OpenOCD. It should look as follows:
$ src/openocd -s tcl -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg
You may need to adjust configuration files after "-f" to match your specifc h/w.
If done correctly you should see:
krzysztof@TK-HP:~/esp/openocd-esp32$ src/openocd -s tcl -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg
Open On-Chip Debugger 0.10.0-dev-gb5ec731 (2017-07-23-21:18)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
force hard breakpoints
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : Target halted. PRO_CPU: PC=0x40080F80 (active)    APP_CPU: PC=0x400D0F58
Posted: Mon Jul 24, 2017 2:32 pm
by justinmreina
this works, thank you :)!!
Original
See attached 'JTAG Installation Process - Jmr.txt':26 for the originally applied command -
./src/openocd -s ./tcl -f ./esp32.cfg
Command Used
Here was my applied command (DevKitC Board, Segger J-Link EDU Programmer). Note that the unit connection was not successful, but the JTAG connection to my programmer was, mission accomplished!
./src/openocd -s tcl -f interface/jlink.cfg -f board/esp-wroom-32.cfg
Response
	jmreina@jmreina-ubuntu:~/openocd-esp32$ ./src/openocd -s tcl -f interface/jlink.cfg -f board/esp-wroom-32.cfg
	Open On-Chip Debugger 0.10.0-dev-gb5ec731 (2017-07-21-19:20)
	Info : No device selected, using first device.
	Info : J-Link V9 compiled Dec 16 2016 15:34:10
	Info : Hardware version: 9.40
	Info : VTarget = 0.000 V
	Info : Reduced speed from 20000 kHz to 15000 kHz (maximum).
	Error: JTAG scan chain interrogation failed: all zeroes
	Error: esp32.cpu0: IR capture error; saw 0x00 not 0x01
	Error: cpu0: esp32_fetch_all_regs (line 163): DSR (FFFFFFFF) indicates target still busy!
	Error: cpu0: esp32_fetch_all_regs (line 163): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
	Error: cpu0: esp32_fetch_all_regs (line 163): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
	Error: cpu0: esp32_fetch_all_regs (line 190): DSR (FFFFFFFF) indicates target still busy!
	Error: cpu0: esp32_fetch_all_regs (line 190): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
	Error: cpu0: esp32_fetch_all_regs (line 190): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
	Error: Exception reading pc!
	Info : Target halted. PRO_CPU: PC=0x00000000             APP_CPU: PC=0x00000000 (active)
	Error: cpu0: xtensa_write_memory (line 696): DSR (FFFFFFFF) indicates target still busy!
	Error: cpu0: xtensa_write_memory (line 696): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
	Error: cpu0: xtensa_write_memory (line 696): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
	Warn : esp32: Failed writing 4 bytes at address 0x3FF5F064, data - a1, 3a, d8, 50, a1, 3a, d8, 50
	embedded:startup.tcl:21: Error:
	in procedure 'init'
	in procedure 'ocd_bouncer'
	in procedure 'flash'
	in procedure 'esp_core_halt'
	in procedure 'esp32' called at file "tcl/target/esp32.cfg", line 37
	at file "embedded:startup.tcl", line 21
	Info : esp32: Debug controller was reset (pwrstat=0xFF, after clear 0xFF).
	Info : esp32: Core was reset (pwrstat=0xFF, after clear 0xFF).
OpenOCD installation issues post - Suppl.zip
See attached for all of the ref & debug content I used to work to solution!
(468.09 KiB) Downloaded 684 times
Posted: Mon Jul 24, 2017 4:00 pm
by krzychb
I am happy to see you are progressing!
Configuration files have changed with latest release of OpenOCD and "jtag_debugging_for_esp32_en.pdf v1.0" is not updated to reflect these changes.
Regarding the error log, it looks like communication speed or wiring problem:
Basing on command to start OpenOCD I assume you are using an external JTAG adapter. In such case it is unlikely to achieve communication at 20 MHz.
If not done already I would reduce the speed several times (in range 10x - 100x depending on the cable length) by changing the following line in configuration:
adapter_khz 20000
If the issue persists then check the wiring.
If the wiring looks correct:
- post a photo of your set up,
- specify types of ESP32 board & JTAG interface used,
- provide a list how the pins of JTAG interface and ESP32 module are connected.
Posted: Tue Jul 25, 2017 6:16 pm
by justinmreina
Hi krzychb,
Thank you 20kHz works! The J-Link successfully connects now but JTAG is not established to my ESP32. Here is my hardware setup -
Setup
Board: Espressif DevKit-C
JTAG: Segger J-Link EDU
OS: Ubuntu 16.04 (Virtualbox, Win10 PC)
Here is what I see in response (see 'JTAG Response.pdf' for full response) -
jmreina@jmreina-ubuntu:~/esp/openocd-esp32$ ./src/openocd -s tcl -f interface/jlink.cfg -f
Open On-Chip Debugger 0.10.0-dev-gb5ec731 (2017-07-23-10:57)
adapter speed: 20 kHz
Info : VTarget = 3.316 V
Info : clock speed 20 kHz
Thoughts? What is missing? Why does it say "Info : No device selected, using first device", how to specify the device?
Thanks for your help here!
Posted: Wed Jul 26, 2017 10:27 am
by krzychb
HI justinmreina,
You are clearly almost there.
I am not sure about wiring:
1. I would not connect 3.3V between ESP32 and Segger J-Link. ESP32 should be powered through own USB
2. From the pictures you posted it looks like one of lines is connected to GPIO27 while GPIO12 is not connected
Please see below set-up that I have just tested and works correctly.
All wires are about 10 cm long. In fact in this setup it is working with "adapter_khz" at 26 MHz that is maximum discussed in documentation. I have tested it for about 2h transmitting application traces as described in http://esp-idf.readthedocs.io/en/latest ... trace.html
Connection of JTAG interface to ESP32 DevKitC
Example wiring of Olimex ARM-USB-OCD-H JTAG to ESP32 DevKitC
Posted: Thu Jul 27, 2017 12:50 am
by justinmreina
It works now, thank you!! It did require connection of VCC to the JTAG for successful connection, and then ready to go!
That graphic you shared, wow this is good content. I've encapsulated it into my wiring write-up, quite useful here see attached!
Posted: Thu Jul 27, 2017 1:06 am
by justinmreina
My setup is almost complete in Eclipse, very eager to get started in dev. I've got one last step here, debugging. Is there a good 'hello world' ref to GDB/Eclipse debugging for the ESP32?
Known ESP-IDF Debugging Ref
- ESP-IDF: Docs » API Guides » Debugging
Debugging Goals
- HW/SW Code Breakpoints
- Code Stepping
- Register R/W
Each time I dive into the posted instructions, I get a bit intimidated and back down. What is the easy way to get started here?
Posted: Sat Jul 29, 2017 3:52 am
by justinmreina
any thoughts or ideas here? If anyone has anything toss it up and I'll dive in, with full report back in response! :)
Posted: Sat Jul 29, 2017 6:23 am
by igrr
Please check the updated guide for setting up JTAG debugging for ESP32 in Eclipse: http://esp-idf.readthedocs.io/en/latest ... er-eclipse and the debugging examples section: http://esp-idf.readthedocs.io/en/latest ... es-eclipse
