ESP.restart() does't trigger complete boot after Update()
marchingband
Postby marchingband » Mon Jan 03, 2022 1:34 am
I have some code that runs Update() from data stored in eMMC. The process works great, but the call to ESP.Restart() doesn't cause a successful boot. Resetting the ESP32 after this, the new firmware boots perfectly.
Code: Untitled.c Select all
    if(Update.end()){
if(Update.isFinished()){
sdmmc_host_deinit();
delay(1000);
ESP.restart();
log_e("Update.isFinished() : false");
log_e("Update.end() : false");
Verbose log:
rst:0xc (SW_CPU_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:10944
load:0x40080400,len:6388
entry 0x400806b4
Then the boot process freezes at "entry 0x400806b4".
Any idea how I can get the boot process to complete, without having to manually restart using the reset button or cycling the power?
Thanks!
marchingband
Re: ESP.restart() does't trigger complete boot after Update()
Postby marchingband » Tue Jan 04, 2022 2:38 am
Does anyone have any ideas how I could debug this event better?
marchingband
Postby marchingband » Tue Jan 04, 2022 9:58 pm
I am using an ESP32 WROVER-B module on a custom PCB.
Does this look like it could be a power issue?
WiFive
Postby WiFive » Tue Jan 04, 2022 10:37 pm
Do you have flash voltage set to 3.3v in efuse?
marchingband
Postby marchingband » Wed Jan 05, 2022 1:04 am
yes i burned the fuses for 3.3v flash.
I have the 16MB flash version of the WROVER-B.
ullixesp
Postby ullixesp » Wed Jan 05, 2022 9:07 am
I had my own share of confusion and problems around the ESP.restart() and ended up using a watchdog timer forced reset to trigger a full ESP32 reset. Solved all my problems.
// needed for the forced reset
#include <esp_int_wdt.h>
#include <esp_task_wdt.h>
void forcedReset(){
// use the watchdog timer to do a hard restart
// It sets the wdt to 1 second, adds the current process and then starts an
// infinite loop.
  esp_task_wdt_init(1, true);
  esp_task_wdt_add(NULL);
  while(true);  // wait for watchdog timer to be triggered
marchingband
Postby marchingband » Sat Jan 08, 2022 1:03 am
Amazing, thanks so much @ullixesp, I will try this out!
