I installed the vscode extension for esp32 but when I want to see the examples, when asking for the framework, VS Code cannot find it.
I wanted to use the frame by entering esp-idf: contiguration, but only Welcome appears.
restart Visual Studio Code and run this wizard again, and I can't use it.
Could anyone help me please?
problems with esp-idf framework in vs code
Re: problems with esp-idf framework in vs code
There is an issue in Windows that should be fixed in GitHub master.
Could you try this vsix installer https://nightly.link/espressif/vscode-e ... 655771.zip and see if the issue is fixed ?
walter.paz
Thank you very much, it worked by installing it as you told me, you are the best
Users browsing this forum: Amazon [Bot] and 1 guest
