This may be a bit of a novice question, but I am a bit confused about how to put a 6-pin ESP-PROG header on a custom board. Is it ok to simply run the 3.3v VDD pin directly to the ESP32-C3 VIN pin with a few smoothing capacitors?
Also is it recommended to add anything to the TX/RX pins? I have seen some schematics for other boards that either contain resistors or diodes? Thank you!
ESP32-C3-WROOM-02 and ESP-PROG Custom Board
Re: ESP32-C3-WROOM-02 and ESP-PROG Custom Board
Yes, you can run the 3v3 directly to power the Wroom, and there's no need for resistors on the tx/rx lines. Note that you can also skip the esp-prog by connecting an USB cable directly to GPIO18/GPIO19; the ESP32C3 has an internal USB-serial-JTAG device.
Users browsing this forum: Amazon [Bot] and 2 guests
